Introduzione
This guide provides instructions for disassembling a broken LCD screen on the Olympus Stylus 725.
Parti
Nessuna parte richiesta.
The battery is located on the bottom of the camera. Remove the battery by placing your thumb on the buttom flap and sliding the release button away from the side the lens is on. (The screwdriver is simply used as a reference point, no screws need to be removed)
  • The battery is located on the bottom of the camera.
  • Remove the battery by placing your thumb on the buttom flap and sliding the release button away from the side the lens is on. (The screwdriver is simply used as a reference point, no screws need to be removed)
  • Charge the battery for 60-90 minutes if your battery is dead.
  • When installing a charged battery, align the battery appropriately, with the positive signs and negative signs lining up.
Aggiungi Commento
Unscrew the 3mm long cover screws at the corners of the camera using a #00 Philips Screwdriver. Unscrew the 2mm long screws securing the sides of the camera which holds the back panel. Use the same screwdriver. Unscrew the 2mm long screws securing the sides of the camera which holds the back panel. Use the same screwdriver.
  • Unscrew the 3mm long cover screws at the corners of the camera using a #00 Philips Screwdriver.
  • Unscrew the 2mm long screws securing the sides of the camera which holds the back panel. Use the same screwdriver.
Aggiungi Commento
Be careful when removing the back cover, you will need to detach the connecting ribbons Detach the ribbons using your thumb, sliding them out of their slots.
  • Be careful when removing the back cover, you will need to detach the connecting ribbons
  • Detach the ribbons using your thumb, sliding them out of their slots.
Aggiungi Commento
Use a #00 Phillips head screwdriver to remove the screws in the back panel. After removing the back panel,  slide the ribbons off the computer chip to detach them. After removing the back panel,  slide the ribbons off the computer chip to detach them.
  • Use a #00 Phillips head screwdriver to remove the screws in the back panel.
  • After removing the back panel, slide the ribbons off the computer chip to detach them.
Aggiungi Commento
Use tweezers to remove the loosened LCD screen. Be careful to not scratch the new LCD screen when replacing it.
  • Use tweezers to remove the loosened LCD screen.
  • Be careful to not scratch the new LCD screen when replacing it.
  • Carefully place the new screen in place of the old, making sure the label faces up.
Aggiungi Commento
  • Slide the ribbons back onto the computer chip.
Aggiungi Commento
  • Using the #00 Phillips head screwdriver from before, screw the screws in the back into the panel.
Aggiungi Commento
Conclusione
Be sure to test the device by turning it on once the screen has been replaced. Make sure that the new screen works properly.
Bobby Hodges
Membro da: 18/04/2010
49 Reputazione
6 Guide realizzate
Cal Poly, Team 33-71, Johann Spring 2010 Membro di Cal Poly, Team 33-71, Johann Spring 2010
CPSU-JOHANN-S10S33G71
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 7,499
