Salta al contenuto principale
Disassembling Olympus Stylus 725 SW Battery
  1. Disassembling Olympus Stylus 725 SW Battery, Disassembling Olympus Stylus 725 SW Battery: passo 1, immagine 1 di 2 Disassembling Olympus Stylus 725 SW Battery, Disassembling Olympus Stylus 725 SW Battery: passo 1, immagine 2 di 2
    • The battery is located on the bottom of the camera.
    • Remove the battery by placing your thumb on the bottom flap and sliding the release button away from the side the lens is on. (The screwdriver is simply used as a reference point, no screws need to be removed)
    • If the battery is dead, charge it for 60-90 minutes.
    • When installing a charged battery, align the battery appropriately. The positive signs and negative should line up.
Conclusione
Follow these instructions in reverse order to reassemble your device.
Bobby Hodges
Membro da: 04/18/10
49 Reputazione
6 Guide realizzate
Cal Poly, Team 33-71, Johann Spring 2010 Membro di Cal Poly, Team 33-71, Johann Spring 2010
CPSU-JOHANN-S10S33G71
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 13
Tutti i Tempi: 3,262
