Salta al contenuto principale
Disassembling Nokia E61i Volume Control Buttons
Cosa ti serve
  1. Disassembling Nokia E61i Volume Control Buttons, Battery: passo 1, immagine 1 di 2 Disassembling Nokia E61i Volume Control Buttons, Battery: passo 1, immagine 2 di 2
    • Remove the back cover to access the battery. Press the tab on the bottom of the cover.
    • Slide the back cover downwards off of the phone while pressing the tab down.
  2. Disassembling Nokia E61i Volume Control Buttons: passo 2, immagine 1 di 1
    • Locate the bottom-left corner of the phone where there is a spot to remove the battery.
  3. Disassembling Nokia E61i Volume Control Buttons: passo 3, immagine 1 di 1
    • Lift the battery out using your finger.
    • The E61i uses a Nokia BP-4L standard battery.
  4. Disassembling Nokia E61i Volume Control Buttons, Front Cover: passo 4, immagine 1 di 2 Disassembling Nokia E61i Volume Control Buttons, Front Cover: passo 4, immagine 2 di 2
    • Remove the four screws that secure the front cover to the rest of the phone using a T7 screwdriver.
  5. Disassembling Nokia E61i Volume Control Buttons: passo 5, immagine 1 di 1
    • Remove the cover by pulling it up and off.
  6. Disassembling Nokia E61i Volume Control Buttons, Display: passo 6, immagine 1 di 2 Disassembling Nokia E61i Volume Control Buttons, Display: passo 6, immagine 2 di 2
    • Take off the casing and keyboard.
    • Remove the screws while holding the screen in place using a Torx T6 screwdriver.
    • Remove the single screw while holding the screen in place using a Torx T5 screwdriver.
    • Lift the ribbon off of the contact with the motherboard.
    • Firmly press the contacts into place to connect the ribbon and the motherboard when reassembling.
  7. Disassembling Nokia E61i Volume Control Buttons: passo 7, immagine 1 di 2 Disassembling Nokia E61i Volume Control Buttons: passo 7, immagine 2 di 2
    • Gently pull the screen off of the phone.
    • Be sure not to rip the sticker that connects the display and the motherboard.
    • Pull the silver case off to completely free the cracked or damaged screen.
  8. Disassembling Nokia E61i Volume Control Buttons, Motherboard: passo 8, immagine 1 di 3 Disassembling Nokia E61i Volume Control Buttons, Motherboard: passo 8, immagine 2 di 3 Disassembling Nokia E61i Volume Control Buttons, Motherboard: passo 8, immagine 3 di 3
    • Pull the green motherboard from the back casing.
  9. Disassembling Nokia E61i Volume Control Buttons, Volume Control Buttons: passo 9, immagine 1 di 1
    • The volume control buttons are secured to the frame only by their fit around a small piece of the plastic. Using a small flat-head screwdriver or other flat object, lift the ribbon over this piece of the cover.
  10. Disassembling Nokia E61i Volume Control Buttons: passo 10, immagine 1 di 1
    • Next, remove the volume control buttons from the cover by pushing or pulling them out away from the interior of the cover.
Conclusione
Cal Poly, Team 9-63, Walters Spring 2011 Membro di Cal Poly, Team 9-63, Walters Spring 2011
CPSU-WALTERS-S11S9G63
5 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,608
