Introduzione
This guide will show you how to remove the assembly that houses the phone's keypad, speaker and screen.
Parti
Nessuna parte richiesta.
Press the button to remove the back cover. Pull the cover downward and lift it off while still pressing the button.
  • Press the button to remove the back cover.
  • Pull the cover downward and lift it off while still pressing the button.
Aggiungi Commento
Lift the battery out of the phone by pushing down from the top and pulling out
  • Lift the battery out of the phone by pushing down from the top and pulling out
Aggiungi Commento
Grip the front cover from the bottom.
  • Grip the front cover from the bottom.
Aggiungi Commento
Lift the front cover off.
  • Lift the front cover off.
Aggiungi Commento
Locate 6 screws on front of assembly and unscrew them using a T6 torx screwdriver.
  • Locate 6 screws on front of assembly and unscrew them using a T6 torx screwdriver.
Aggiungi Commento
Insert spudger along edge of assembly and gently lift assembly away from case
  • Insert spudger along edge of assembly and gently lift assembly away from case
Aggiungi Commento
Remove assembly from phone
  • Remove assembly from phone
Aggiungi Commento
Conclusione
Colby Leslie
Membro da: 05/10/2010
1 Reputazione
9 Guide realizzate
Cal Poly, Team 22-3, Maness Fall 2010 Membro di Cal Poly, Team 22-3, Maness Fall 2010
CPSU-MANESS-F10S22G3
4 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 898
