Introduzione
This will guide you through removing the battery. No tools required.
Apply pressure to the battery casing (below the camera) with your thumb and pull towards the bottom of the phone. Lift the battery case off of the phone.
  • Apply pressure to the battery casing (below the camera) with your thumb and pull towards the bottom of the phone.
  • Lift the battery case off of the phone.
Aggiungi Commento
Gently pull the battery out of the phone, using your thumb to apply pressure to the battery at the bottom of the phone. The battery should lift out with minimal resistance. The battery should lift out with minimal resistance.
  • Gently pull the battery out of the phone, using your thumb to apply pressure to the battery at the bottom of the phone.
  • The battery should lift out with minimal resistance.
Aggiungi Commento
Conclusione
Erik Lindahl
Membro da: 18/04/2010
48 Reputazione
8 Guide realizzate
Cal Poly, Team 10-46, Garner Spring 2010 Membro di Cal Poly, Team 10-46, Garner Spring 2010
CPSU-GARNER-S10S10G46
4 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,494
