Introduzione
This guide will show you how to remove the LCD Display from the Nokia 3560.
Parti
Nessuna parte richiesta.
Press down on the release latch on the bottom of the cover. Once the latch is released, lift the cover from the phone.
  • Press down on the release latch on the bottom of the cover.
  • Once the latch is released, lift the cover from the phone.
Aggiungi Commento
Lift the front case off of the phone body.
  • Lift the front case off of the phone body.
Aggiungi Commento
Lift the keypad off of the phone. Lift the keypad off of the phone.
  • Lift the keypad off of the phone.
Aggiungi Commento
The screen is held to the body by six screws.
  • The screen is held to the body by six screws.
Aggiungi Commento
Unscrew the six screws with a Torx screwdriver (six-pointed star shaped bit).
  • Unscrew the six screws with a Torx screwdriver (six-pointed star shaped bit).
Aggiungi Commento
Insert a flat screwdriver between the black body and plastic layer. Insert a flat screwdriver between the black body and plastic layer.
  • Insert a flat screwdriver between the black body and plastic layer.
Aggiungi Commento
Pry the layers apart. The LCD and plastic layer will lift out as one piece.
  • Pry the layers apart. The LCD and plastic layer will lift out as one piece.
Aggiungi Commento
Conclusione
Sam Ryan
Membro da: 18/04/2010
1 Reputazione
16 Guide realizzate
Cal Poly, Team 30-39, Garner Spring 2010 Membro di Cal Poly, Team 30-39, Garner Spring 2010
CPSU-GARNER-S10S30G39
5 Membri
16 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,859
