Salta al contenuto principale
Disassembling Nokia 3395 Inner Components
Cosa ti serve
  1. Disassembling Nokia 3395 Inner Components, Back Case: passo 1, immagine 1 di 3 Disassembling Nokia 3395 Inner Components, Back Case: passo 1, immagine 2 di 3 Disassembling Nokia 3395 Inner Components, Back Case: passo 1, immagine 3 di 3
    • Turn the phone off.
    • Hold the phone, and gently press the white button located at the bottom of the phone.
    • While pressing the button, slide the back plate upwards, opening the plate.
  2. Disassembling Nokia 3395 Inner Components, Battery: passo 2, immagine 1 di 2 Disassembling Nokia 3395 Inner Components, Battery: passo 2, immagine 2 di 2
    • Locate grey buttons beneath battery (shown).
    • Spread buttons simultaneously away from each other and the battery will pop out.
    • Remove battery from phone.
  3. Disassembling Nokia 3395 Inner Components, Front Case: passo 3, immagine 1 di 2 Disassembling Nokia 3395 Inner Components, Front Case: passo 3, immagine 2 di 2
    • Push the two black buttons on the side with your thumbs forward. This will release the front faceplate.
    • Flip over the device, and pry the faceplate away.
  4. Disassembling Nokia 3395 Inner Components, Screen: passo 4, immagine 1 di 2 Disassembling Nokia 3395 Inner Components, Screen: passo 4, immagine 2 di 2
    • Remove six T6 screws.
  5. Disassembling Nokia 3395 Inner Components: passo 5, immagine 1 di 2 Disassembling Nokia 3395 Inner Components: passo 5, immagine 2 di 2
    • Insert spudger between screen assembly and phone body.
    • Spread apart as shown. Avoid damaging the screen assembly by removing the screen slowly.
  6. Disassembling Nokia 3395 Inner Components, Logic Board: passo 6, immagine 1 di 2 Disassembling Nokia 3395 Inner Components, Logic Board: passo 6, immagine 2 di 2
    • Remove logic board as shown.
  7. Disassembling Nokia 3395 Inner Components, Inner Components: passo 7, immagine 1 di 1
    • Use the following legend to locate each component:
    • Microphone/power assembly.
    • Vibrating unit.
    • SIM card reader.
    • Audio speaker.
    • Power toggle button.
    • Battery connector.
  8. Disassembling Nokia 3395 Inner Components: passo 8, immagine 1 di 2 Disassembling Nokia 3395 Inner Components: passo 8, immagine 2 di 2
    • Insert spudger between power assembly/micro-phone and phone body.
    • Pry as shown and remove the power assembly/microphone.
  9. Disassembling Nokia 3395 Inner Components: passo 9, immagine 1 di 1
    • Once located, the following components are easily removed by pulling them out with your hand.
    • Vibrating unit.
    • SIM card reader.
    • Audio speaker.
  10. Disassembling Nokia 3395 Inner Components: passo 10, immagine 1 di 2 Disassembling Nokia 3395 Inner Components: passo 10, immagine 2 di 2
    • Audio speaker.
  11. Disassembling Nokia 3395 Inner Components: passo 11, immagine 1 di 2 Disassembling Nokia 3395 Inner Components: passo 11, immagine 2 di 2
    • SIM card reader.
  12. Disassembling Nokia 3395 Inner Components: passo 12, immagine 1 di 2 Disassembling Nokia 3395 Inner Components: passo 12, immagine 2 di 2
    • Vibrating unit.
  13. Disassembling Nokia 3395 Inner Components: passo 13, immagine 1 di 2 Disassembling Nokia 3395 Inner Components: passo 13, immagine 2 di 2
  14. Disassembling Nokia 3395 Inner Components: passo 14, immagine 1 di 2 Disassembling Nokia 3395 Inner Components: passo 14, immagine 2 di 2
Conclusione
Nico Lee
Membro da: 04/19/10
78 Reputazione
6 Guide realizzate
Cal Poly, Team 30-41, Garner Spring 2010 Membro di Cal Poly, Team 30-41, Garner Spring 2010
CPSU-GARNER-S10S30G41
4 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 2,923
