Salta al contenuto principale
Disassembling Nokia 3100b Speaker
Cosa ti serve
  1. Disassembling Nokia 3100b Speaker, Battery: passo 1, immagine 1 di 1
    • Make sure your phone is turned off.
  2. Disassembling Nokia 3100b Speaker: passo 2, immagine 1 di 1
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
  3. Disassembling Nokia 3100b Speaker, SIM Card: passo 3, immagine 1 di 1
    • Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
  4. Disassembling Nokia 3100b Speaker: passo 4, immagine 1 di 1
    • Retrieve your SIM card.
  5. Disassembling Nokia 3100b Speaker, Screen: passo 5, immagine 1 di 1
    • Separate the front cover from the main body of the phone.
  6. Disassembling Nokia 3100b Speaker: passo 6, immagine 1 di 1
    • Remove the six screws along the edges of the phone.
  7. Disassembling Nokia 3100b Speaker: passo 7, immagine 1 di 1
    • Pull the screen assembly from the base of the phone.
  8. Disassembling Nokia 3100b Speaker: passo 8, immagine 1 di 1
    • Carefully lift the keypad portion of the screen assembly from the circuit board.
  9. Disassembling Nokia 3100b Speaker: passo 9, immagine 1 di 1
    • Separate the screen from the circuit board.
    • Reconnect the ports during reassembly or the screen will not function properly.
    • Remember to reconnect the screen to the circuit board when reassembling!
  10. Disassembling Nokia 3100b Speaker: passo 10, immagine 1 di 1
    • Gently push down on the screen to pop it off of the assembly.
  11. Disassembling Nokia 3100b Speaker: passo 11, immagine 1 di 1
    • When the screen falls out the assembly, two white tabs will fall out with it.
    • When reinstalling the screen, insert the tabs with the slanted side pointing upwards so they slide into the assembly.
  12. Disassembling Nokia 3100b Speaker, Speaker: passo 12, immagine 1 di 1
    • Set the screen and the tabs aside.
  13. Disassembling Nokia 3100b Speaker: passo 13, immagine 1 di 1
    • You can now access the speaker.
    • Note the tab on the end of the speaker. It must be placed in correctly in order to reinstall the speaker.
  14. Disassembling Nokia 3100b Speaker: passo 14, immagine 1 di 1
    • Remove the speaker from the assembly.
Conclusione
Cal Poly, Team 29-64, Johann Spring 2010 Membro di Cal Poly, Team 29-64, Johann Spring 2010
CPSU-JOHANN-S10S29G64
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,163
