Introduzione
This guide show you how to access the phone's microphone, the component that receives sound when making a call.
Parti
Nessuna parte richiesta.
Make sure your phone is turned off.
  • Make sure your phone is turned off.
Aggiungi Commento
Press the button on the back of the phone and slide the back panel off.
  • Press the button on the back of the phone and slide the back panel off.
  • Remove the battery by pulling it from the phone.
Aggiungi Commento
Note the small metal frame that  hold the SIM card into place.
  • Note the small metal frame that hold the SIM card into place.
  • Gently pull back the tab and lift open the frame.
Aggiungi Commento
Retrieve your SIM card.
  • Retrieve your SIM card.
Aggiungi Commento
Press the black tabs to release the front cover from the phone.
  • Press the black tabs to release the front cover from the phone.
Aggiungi Commento
Remove the front cover from the phone.
  • Remove the front cover from the phone.
  • Set the front cover, as indicated, aside.
Aggiungi Commento
Remove the screws as they are indicated in the order of the colors of the rainbow. (Red, Orange, Yellow, Green, Blue, Purple.)
  • Remove the screws as they are indicated in the order of the colors of the rainbow. (Red, Orange, Yellow, Green, Blue, Purple.)
Aggiungi Commento
Remove the screen assembly from the phone base.
  • Remove the screen assembly from the phone base.
  • Set the screen assembly aside.
Aggiungi Commento
Note the location of the microphone.
  • Note the location of the microphone.
Aggiungi Commento
Use tweezers to remove the microphone from the phone's base.
  • Use tweezers to remove the microphone from the phone's base.
Aggiungi Commento
The microphone is now removed.
  • The microphone is now removed.
Aggiungi Commento
Conclusione
Cal Poly, Team 29-64, Johann Spring 2010 Membro di Cal Poly, Team 29-64, Johann Spring 2010
CPSU-JOHANN-S10S29G64
3 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,943
