Introduzione
This guide details how to remove the logic board.
Slide the notch downward while pulling the back cover off to remove it. Slide the notch downward while pulling the back cover off to remove it. Slide the notch downward while pulling the back cover off to remove it.
  • Slide the notch downward while pulling the back cover off to remove it.
Aggiungi Commento
Use your fingers to push the battery upward from the bottom. Lift upwards to remove the battery. Lift upwards to remove the battery.
  • Use your fingers to push the battery upward from the bottom.
  • Lift upwards to remove the battery.
Aggiungi Commento
Unscrew the antenna in a counter-clockwise fashion. Remove the aluminum cover.
  • Unscrew the antenna in a counter-clockwise fashion.
  • Remove the aluminum cover.
Aggiungi Commento
Unscrew the 3 screws shown. Lift up the right part of the Nextel logo and unscrew the screw underneath. Lift up the right part of the Nextel logo and unscrew the screw underneath.
  • Unscrew the 3 screws shown.
  • Lift up the right part of the Nextel logo and unscrew the screw underneath.
Aggiungi Commento
DO NOT force the cover off as it could damage the ribbon cable! Gently lift the back cover off.
  • DO NOT force the cover off as it could damage the ribbon cable!
  • Gently lift the back cover off.
Aggiungi Commento
Carefully pry off the connection between the headphone jack and logic board. Carefully pry off the connection between the headphone jack and logic board. Carefully pry off the connection between the headphone jack and logic board.
  • Carefully pry off the connection between the headphone jack and logic board.
Aggiungi Commento
Lift the first logic board off of the rest of the device. Lift the first logic board off of the rest of the device.
  • Lift the first logic board off of the rest of the device.
Aggiungi Commento
Gently lift the second logic board from the rest of the device.
  • Gently lift the second logic board from the rest of the device.
  • DO NOT force the board straight off as it could damage the ribbon cable!
Aggiungi Commento
Using tweezers, carefully pull off the connector shown. Using tweezers, carefully pull off the connector shown.
  • Using tweezers, carefully pull off the connector shown.
Aggiungi Commento
Conclusione
Cal Poly, Team 29-61, Johann Spring 2010 Membro di Cal Poly, Team 29-61, Johann Spring 2010
CPSU-JOHANN-S10S29G61
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 892
