Introduzione
A procedure in replacing the keypad of the device.
Parti
Nessuna parte richiesta.
Use your thumb to slide the back cover locker away from the antenna.
  • Use your thumb to slide the back cover locker away from the antenna.
Aggiungi Commento
Slide the back cover towards the antenna while lifting the cover away from the phone. Slide the back cover towards the antenna while lifting the cover away from the phone.
  • Slide the back cover towards the antenna while lifting the cover away from the phone.
Aggiungi Commento
Place your thumb on the indicated corner while stabilizing the phone and the upper portion of the battery with your forefinger.
  • Place your thumb on the indicated corner while stabilizing the phone and the upper portion of the battery with your forefinger.
Aggiungi Commento
Lift the battery out of the phone while pushing it towards the antenna. Lift the battery out of the phone while pushing it towards the antenna.
  • Lift the battery out of the phone while pushing it towards the antenna.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Once battery is removed, untighten the screws located near the edges of the device with a Phillips #00 Screwdriver.
  • Once battery is removed, untighten the screws located near the edges of the device with a Phillips #00 Screwdriver.
Aggiungi Commento
Grip the device firmly with both hands and carefully open the device. Warning: Interior hardware inside the device can be easily damaged. Warning: Interior hardware inside the device can be easily damaged.
  • Grip the device firmly with both hands and carefully open the device.
  • Warning: Interior hardware inside the device can be easily damaged.
Aggiungi Commento
Carefully remove the hardware by gripping the side of the hardware attachment with a tweezer. Carefully remove the hardware by gripping the side of the hardware attachment with a tweezer.
  • Carefully remove the hardware by gripping the side of the hardware attachment with a tweezer.
Aggiungi Commento
Carefully grip the side of the hardware attachment with a tweezer and detach from device. Carefully grip the side of the hardware attachment with a tweezer and detach from device.
  • Carefully grip the side of the hardware attachment with a tweezer and detach from device.
Aggiungi Commento
Place the back of the device on your hand and flip it over with the other hand. Carefully lift the device to remove interior hardware. The structure of the keypad should easily be loose from flipping the device.
  • Place the back of the device on your hand and flip it over with the other hand.
  • Carefully lift the device to remove interior hardware.
  • The structure of the keypad should easily be loose from flipping the device.
Aggiungi Commento
Carefully remove the keypad by griping on the side of the plastic with a tweezer. WARNING: The plastic keypad is sensitive and can be easily damaged. WARNING: The plastic keypad is sensitive and can be easily damaged.
  • Carefully remove the keypad by griping on the side of the plastic with a tweezer.
  • WARNING: The plastic keypad is sensitive and can be easily damaged.
Aggiungi Commento
Conclusione
Tony Chen
Membro da: 08/04/2010
1 Reputazione
1 Guida realizzata
Cal Poly, Team 34-56, Forte Spring 2010 Membro di Cal Poly, Team 34-56, Forte Spring 2010
CPSU-FORTE-S10S34G56
4 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,577
