Salta al contenuto principale
Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis
Cosa ti serve
  1. Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Remove serial port connection: passo 1, immagine 1 di 3 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Remove serial port connection: passo 1, immagine 2 di 3 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Remove serial port connection: passo 1, immagine 3 di 3
    • Loosen the screws on the serial port by turning them counter clockwise by hand.
    • After loosening the screws, pull the serial port out.
  2. Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Remove Lid: passo 2, immagine 1 di 3 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Remove Lid: passo 2, immagine 2 di 3 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Remove Lid: passo 2, immagine 3 di 3
    • Lift lid to its vertical position.
    • Pull lid straight up to remove it from the scanner.
  3. Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Detach plastic latches: passo 3, immagine 1 di 3 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Detach plastic latches: passo 3, immagine 2 di 3 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Detach plastic latches: passo 3, immagine 3 di 3
    • Push the plastic opening tools into the crack between the top and the bottom of the chassis.
  4. Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Continue latch detachment: passo 4, immagine 1 di 3 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Continue latch detachment: passo 4, immagine 2 di 3 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Continue latch detachment: passo 4, immagine 3 di 3
    • After placing one plastic opening tool into the slit, slide other plastic opening tools along the slit to detach the top from the bottom of the chassis.
    • Go all the way along the chassis until you can lift the upper lid.
  5. Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Fully remove the upper lid: passo 5, immagine 1 di 3 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Fully remove the upper lid: passo 5, immagine 2 di 3 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Fully remove the upper lid: passo 5, immagine 3 di 3
    • Do not fully remove the lid until you remove the ribbon cable attached to the front of the upper lid.
    • Do this by grabbing the upper lid from the sides and rotating it ninety degrees so it is perpendicular to the bottom lid.
    • Grab the ribbon cable and gently pull it out of its slot with your fingers.
    • The upper lid can now safely be removed from the bottom lid.
Conclusione
Cal Poly, Team 6-9, Regan Fall 2011 Membro di Cal Poly, Team 6-9, Regan Fall 2011
CPSU-REGAN-F11S6G9
2 Membri
22 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,946
