Salta al contenuto principale
Disassembling LG 440G Rear casing
Cosa ti serve
  1. Disassembling LG 440G Rear casing, Turn off phone.: passo 1, immagine 1 di 1
    • Turn the device off.
    • To do so, press and hold the red button.
  2. Disassembling LG 440G Rear casing, Flip phone.: passo 2, immagine 1 di 1
    • Flip the phone over.
  3. Disassembling LG 440G Rear casing, Rear cover removal.: passo 3, immagine 1 di 1
    • Slide the rear cover downward
    • Lift it off to access the battery
  4. Disassembling LG 440G Rear casing, Removal of battery.: passo 4, immagine 1 di 1
    • Locate the small rounded recess to get access to the battery
    • Gently, lift the battery
  5. Disassembling LG 440G Rear casing, Unscrew six screws along edges of casing: passo 5, immagine 1 di 1
    • Use a Phillips #00 screw driver to remove six screws.
    • Save screws for reassembly.
  6. Disassembling LG 440G Rear casing, Lift casing cover: passo 6, immagine 1 di 2 Disassembling LG 440G Rear casing, Lift casing cover: passo 6, immagine 2 di 2
    • Run the plastic opening tool along the edge of the phone to release the casing cover.
    • Lift the casing cover.
Conclusione
Emily Class
Membro da: 02/17/15
107 Reputazione
1 Guida realizzata
Ohio State, Team 1-1, Buehl Winter 2015 Membro di Ohio State, Team 1-1, Buehl Winter 2015
OSU-BUEHL-W15S1G1
4 Membri
8 Guide realizzate
Un commento
this would be most probably, the same guide to tear down the LG B470
douglas flores - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,647
