Introduzione
Outline what you are going to teach someone how to do.
Parti
Nessuna parte richiesta.
Turn off the camera.
  • Turn off the camera.
    • Locate the power switch on the front of the camera below the camera lens.
    • Slide the switch to the off position.
Aggiungi Commento
Locate the 3 screws that hold the back cover to the camera. One screw is located on the film opener side of the camera.
  • Locate the 3 screws that hold the back cover to the camera.
    • One screw is located on the film opener side of the camera.
    • The other screws are located on the opposite side of the camera.
Aggiungi Commento
Use the Phillips #00 Precision Screwdriver and remove the screws on the back cover. Use the Phillips #00 Precision Screwdriver and remove the screws on the back cover. Use the Phillips #00 Precision Screwdriver and remove the screws on the back cover.
  • Use the Phillips #00 Precision Screwdriver and remove the screws on the back cover.
Aggiungi Commento
Open the film door to remove the back cover. Slide the film door lever to the left until the film door opens.
  • Open the film door to remove the back cover.
    • Slide the film door lever to the left until the film door opens.
Aggiungi Commento
Use a plastic opening tool to pry the case open until a small gap is present. Repeat this process at the top and bottom of the film door to loosen it.
  • Use a plastic opening tool to pry the case open until a small gap is present.
    • Repeat this process at the top and bottom of the film door to loosen it.
Aggiungi Commento
Grab the top and bottom of the case firmly as shown. Gently remove the back of the camera case with a slight twisting motion. Gently remove the back of the camera case with a slight twisting motion.
  • Grab the top and bottom of the case firmly as shown.
    • Gently remove the back of the camera case with a slight twisting motion.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Locate the 3 screws on the camera that hold the front cover of the camera to the camera body. The first 2 are located on the bottom of the camera.
  • Locate the 3 screws on the camera that hold the front cover of the camera to the camera body.
    • The first 2 are located on the bottom of the camera.
    • The last screw is located behind the flash module.
      • Turn the camera on, and raise the flash module to locate the flash module screw.
Aggiungi Commento
Remove the 2 screws at the base of the camera housing. Use the Phillips #00 Precision Screwdriver and remove the screws.
  • Remove the 2 screws at the base of the camera housing.
    • Use the Phillips #00 Precision Screwdriver and remove the screws.
    • Repeat this process for the screw behind the flash module.
Aggiungi Commento
Remove the screw located under the flash module using the Phillips #00 Precision Screwdriver. Remove the screw located under the flash module using the Phillips #00 Precision Screwdriver.
  • Remove the screw located under the flash module using the Phillips #00 Precision Screwdriver.
Aggiungi Commento
Remove the flash cover. Remove the flash module by twisting it up and outward of the camera housing.
  • Remove the flash cover.
    • Remove the flash module by twisting it up and outward of the camera housing.
    • The cover can now be be removed.
Aggiungi Commento
Remove the film door lever. Remove the screw holding the film lever in place by using a Phillips #00 Precision Screwdriver.
  • Remove the film door lever.
    • Remove the screw holding the film lever in place by using a Phillips #00 Precision Screwdriver.
    • Using a plastic opening tool, gently pry the switch upwards to remove it.
Aggiungi Commento
Open the battery door by pushing the lever towards the arrow indicated.
  • Open the battery door by pushing the lever towards the arrow indicated.
Aggiungi Commento
Remove the front cover. Insert your thumb in the film hole and gently pry the bottom loose. Once the front is loose, gently pull it out.
  • Remove the front cover.
    • Insert your thumb in the film hole and gently pry the bottom loose.
    • Once the front is loose, gently pull it out.
Aggiungi Commento
Locate the 3 screws on the top of the camera.
  • Locate the 3 screws on the top of the camera.
    • These will be removed in the next step.
Aggiungi Commento
Remove the 3 screws using the Phillips #00 Precision Screwdriver. Remove the 3 screws using the Phillips #00 Precision Screwdriver. Remove the 3 screws using the Phillips #00 Precision Screwdriver.
  • Remove the 3 screws using the Phillips #00 Precision Screwdriver.
Aggiungi Commento
Remove the LCD. Gently pry the LCD and plastic bezel upward with a plastic opening tool.
  • Remove the LCD.
    • Gently pry the LCD and plastic bezel upward with a plastic opening tool.
    • Remove LCD and replace as needed.
Aggiungi Commento
Conclusione
David Cottrell
Membro da: 04/10/2011
58 Reputazione
5 Guide realizzate
UW Stout, Team 1-2, Zhou Fall 2011 Membro di UW Stout, Team 1-2, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G2
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 673
