Parti
Nessuna parte richiesta.
Turn off the camera.
  • Turn off the camera.
    • Locate the power switch on the front of the camera below the camera lens.
    • Slide the switch to the off position.
Aggiungi Commento
Locate the 3 screws that hold the back cover to the camera. One screw is located on the film opener side of the camera.
  • Locate the 3 screws that hold the back cover to the camera.
    • One screw is located on the film opener side of the camera.
    • The other screws are located on the opposite side of the camera.
Aggiungi Commento
Use the Phillips #00 Precision Screwdriver and remove the screws on the back cover. Use the Phillips #00 Precision Screwdriver and remove the screws on the back cover. Use the Phillips #00 Precision Screwdriver and remove the screws on the back cover.
  • Use the Phillips #00 Precision Screwdriver and remove the screws on the back cover.
Aggiungi Commento
Open the film door to remove the back cover. Slide the film door lever to the left until the film door opens.
  • Open the film door to remove the back cover.
    • Slide the film door lever to the left until the film door opens.
Aggiungi Commento
Use a plastic opening tool to pry the case open until a small gap is present. Repeat this process at the top and bottom of the film door to loosen it.
  • Use a plastic opening tool to pry the case open until a small gap is present.
    • Repeat this process at the top and bottom of the film door to loosen it.
Aggiungi Commento
Grab the top and bottom of the case firmly as shown. Gently remove the back of the camera case with a slight twisting motion. Gently remove the back of the camera case with a slight twisting motion.
  • Grab the top and bottom of the case firmly as shown.
    • Gently remove the back of the camera case with a slight twisting motion.
Aggiungi Commento
Conclusione
David Cottrell
Membro da: 04/10/2011
58 Reputazione
5 Guide realizzate
UW Stout, Team 1-2, Zhou Fall 2011 Membro di UW Stout, Team 1-2, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G2
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 421
