Introduzione
These instructions will demonstrate how to remove the camera from the KDDI Kyocera A5521K.
Pry, with a metal probe, the black covers that are located by the pivoting joints of the phone. Beneath the covers are screws. Beneath the covers are screws.
  • Pry, with a metal probe, the black covers that are located by the pivoting joints of the phone.
    • Beneath the covers are screws.
Aggiungi Commento
Remove the screws using a Y0 screwdriver.
  • Remove the screws using a Y0 screwdriver.
Aggiungi Commento
Use the iPod pry tool to remove the outer screen. Two screws are now visible. Be careful not to crack the screen upon removal.  It is adhered strongly to the phone.
  • Use the iPod pry tool to remove the outer screen.
    • Two screws are now visible.
    • Be careful not to crack the screen upon removal. It is adhered strongly to the phone.
Aggiungi Commento
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Use the Y0 screwdriver to remove the screws.
  • Use the Y0 screwdriver to remove the screws.
Aggiungi Commento
Use the iPod pry tool to loosen the faceplate from the phone. Slide the pry tool along the entire crease of the faceplate to completely detach it.
  • Use the iPod pry tool to loosen the faceplate from the phone.
    • Slide the pry tool along the entire crease of the faceplate to completely detach it.
Aggiungi Commento
Separate the faceplate from the phone. Separate the faceplate from the phone. Separate the faceplate from the phone.
  • Separate the faceplate from the phone.
Aggiungi Commento
Firmly grab the flexible circuit with tweezers to detach (or use your fingers if you can manage a firm grip). Firmly grab the flexible circuit with tweezers to detach (or use your fingers if you can manage a firm grip).
  • Firmly grab the flexible circuit with tweezers to detach (or use your fingers if you can manage a firm grip).
Aggiungi Commento
Carefully pry up the camera unit with a spudger. Be careful not to damage the camera unit. The camera should now be separated from the phone.
  • Carefully pry up the camera unit with a spudger.
    • Be careful not to damage the camera unit.
    • The camera should now be separated from the phone.
Aggiungi Commento
Conclusione
Dominic Grisafe
Membro da: 15/04/2010
133 Reputazione
20 Guide realizzate
Cal Poly, Team 28-25, Regan Spring 2010 Membro di Cal Poly, Team 28-25, Regan Spring 2010
CPSU-REGAN-S10S28G25
4 Membri
20 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,404
