Introduzione
These instructions will demonstrate how to remove the back plate from the KDDI Kyocera A5521K.
Parti
Nessuna parte richiesta.
Turn the phone over to expose the battery cover. Apply pressure to the back of the battery cover to slide it down. The battery cover is now separate from the phone.
  • Turn the phone over to expose the battery cover.
  • Apply pressure to the back of the battery cover to slide it down.
  • The battery cover is now separate from the phone.
Aggiungi Commento
Remove the battery by pushing it up and out from the bottom. The battery, cover, and phone should now be separated. The battery, cover, and phone should now be separated.
  • Remove the battery by pushing it up and out from the bottom.
  • The battery, cover, and phone should now be separated.
Aggiungi Commento
Remove the four screws with the Y0 screwdriver. Remove the four screws with the Y0 screwdriver.
  • Remove the four screws with the Y0 screwdriver.
Aggiungi Commento
Remove the black, rubber screw caps towards the top of the back of the phone to reveal two additional screws. Remove the two screws with a Y0 screwdriver.
  • Remove the black, rubber screw caps towards the top of the back of the phone to reveal two additional screws.
  • Remove the two screws with a Y0 screwdriver.
Aggiungi Commento
Rotate the phone 180 degrees. Carefully separate the back plate from the remainder of the phone. The back plate should now be detached from the rest of the phone.
  • Rotate the phone 180 degrees.
  • Carefully separate the back plate from the remainder of the phone.
  • The back plate should now be detached from the rest of the phone.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Dominic Grisafe
Membro da: 15/04/2010
133 Reputazione
20 Guide realizzate
Cal Poly, Team 28-25, Regan Spring 2010 Membro di Cal Poly, Team 28-25, Regan Spring 2010
CPSU-REGAN-S10S28G25
4 Membri
20 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,656
