Introduzione
Many of the important components of the stereo are located on the inside of the device. To get to these components, you must remove the internal components of the device.
Flip the stereo so the CD opening is face down. With two fingers, pinch the tabs and lift up to open the battery protection cover.
  • Flip the stereo so the CD opening is face down.
  • With two fingers, pinch the tabs and lift up to open the battery protection cover.
Aggiungi Commento
Using a spudger or your fingers, push up against the positive end of the battery. Once it is loose, lift the battery out. Repeat until all eight batteries are removed.
  • Using a spudger or your fingers, push up against the positive end of the battery. Once it is loose, lift the battery out.
  • Repeat until all eight batteries are removed.
  • Make sure the batteries are facing the right direction. If the device does not turn on, you may have the batteries in the opposite orientation.
Aggiungi Commento
With a Phillips #2 screwdriver, remove two 2mm screws.
  • With a Phillips #2 screwdriver, remove two 2mm screws.
Aggiungi Commento
Using a long Phillips #2 screwdriver, remove one 6mm screw located inside the battery compartment. Use the same screwdriver to remove four more 6mm screws along the outside of the case.
  • Using a long Phillips #2 screwdriver, remove one 6mm screw located inside the battery compartment.
  • Use the same screwdriver to remove four more 6mm screws along the outside of the case.
Aggiungi Commento
With a plastic opening tool, wedge the bottom shell from the main speaker face along the edge. The bottom cover has two red and two yellow wires attached to it that you don't want to pull off. Handle the casing carefully. Once the pieces are separated, pull them apart and place the bottom cover aside, near the stereo.
  • With a plastic opening tool, wedge the bottom shell from the main speaker face along the edge.
  • The bottom cover has two red and two yellow wires attached to it that you don't want to pull off. Handle the casing carefully.
  • Once the pieces are separated, pull them apart and place the bottom cover aside, near the stereo.
Aggiungi Commento
With a Phillips #2 screwdriver, remove five 5mm screws from the "quarter circle" circuit board. More wires! Handle the circuit board carefully and take caution not to stretch the red and white wires connected the board to the other components.
  • With a Phillips #2 screwdriver, remove five 5mm screws from the "quarter circle" circuit board.
  • More wires! Handle the circuit board carefully and take caution not to stretch the red and white wires connected the board to the other components.
  • Remove the green quarter circle circuit board and place to the side.
Aggiungi Commento
On the brown side of the quarter circle circuit board, remove the two white ribbon cables with pink stripes attached to a plastic connector. To do this, pinch the tabs with your hands while pulling outward on the connector.
  • On the brown side of the quarter circle circuit board, remove the two white ribbon cables with pink stripes attached to a plastic connector. To do this, pinch the tabs with your hands while pulling outward on the connector.
Aggiungi Commento
With a Phillips #2 screwdriver, remove four 6mm screws from the rectangular circuit board.
  • With a Phillips #2 screwdriver, remove four 6mm screws from the rectangular circuit board.
Aggiungi Commento
Remove the two white ribbon cables attached to white plastic connectors from the circuit board by pinching the tabs with your hands and pulling outward on the connector.
  • Remove the two white ribbon cables attached to white plastic connectors from the circuit board by pinching the tabs with your hands and pulling outward on the connector.
Aggiungi Commento
Red and white wires are attached to this board as well. Once again, be careful not to stretch these.
  • Red and white wires are attached to this board as well. Once again, be careful not to stretch these.
  • Remove the rectangular circuit board and place it to the side.
Aggiungi Commento
With a Phillips #2 screwdriver, remove two 5mm screws from the black plastic frame which previously held up the rectangular circuit board.
  • With a Phillips #2 screwdriver, remove two 5mm screws from the black plastic frame which previously held up the rectangular circuit board.
  • Remove the black plastic frame.
Aggiungi Commento
With a Phillips #1 screwdriver, remove four 3mm screws from the silver metal circuit board. This board has two white ribbons attached to it. Once again, be careful not to stretch these.
  • With a Phillips #1 screwdriver, remove four 3mm screws from the silver metal circuit board.
  • This board has two white ribbons attached to it. Once again, be careful not to stretch these.
  • Remove and place the metal circuit board to the side.
Aggiungi Commento
With a Phillips #2 screwdriver, remove the two 3mm screws from the black plastic tuner frame.
  • With a Phillips #2 screwdriver, remove the two 3mm screws from the black plastic tuner frame.
Aggiungi Commento
Conclusione
Daniel Hodges
Membro da: 14/10/2013
301 Reputazione
3 Guide realizzate
Cal Poly, Team 4-31, Amido Fall 2013 Membro di Cal Poly, Team 4-31, Amido Fall 2013
CPSU-AMIDO-F13S4G31
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 469
