Introduzione
This guide will explain step by step how to remove the outer cases of the IBM WorkPad c3.
Parti
Nessuna parte richiesta.
Turn the device over so that the screen is facing down. In the next step the device will be heated, so the screen must be turned over to prevent heat damage to the LCD/Digitizer.
  • Turn the device over so that the screen is facing down.
  • In the next step the device will be heated, so the screen must be turned over to prevent heat damage to the LCD/Digitizer.
Aggiungi Commento
Using a hair dryer, slowly heat the edges of the WorkPad.
  • Using a hair dryer, slowly heat the edges of the WorkPad.
  • Spend at least one minute heating each side of the device. This will melt the glue holding the case together, and allow it to be removed.
  • Be sure not to touch the device directly after heating as it will be extremely hot. Use a towel or oven mitt to grab it.
Aggiungi Commento
Use a plastic opening tool to pry the back case from the WorkPad. If the rear cover is not coming off very easily, you probably need to reheat the case in order to sufficiently melt the glue.
  • Use a plastic opening tool to pry the back case from the WorkPad.
  • If the rear cover is not coming off very easily, you probably need to reheat the case in order to sufficiently melt the glue.
Aggiungi Commento
Conclusione
Emily Falkenstein
Membro da: 05/10/2010
51 Reputazione
5 Guide realizzate
Cal Poly, Team 21-35, Regan Fall 2010 Membro di Cal Poly, Team 21-35, Regan Fall 2010
CPSU-REGAN-F10S21G35
3 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,216
