Salta al contenuto principale
Disassembling IBM ThinkPad A30 Modem and Ethernet Cards
Cosa ti serve
  1. Disassembling IBM ThinkPad A30 Modem and Ethernet Cards, Battery: passo 1, immagine 1 di 2 Disassembling IBM ThinkPad A30 Modem and Ethernet Cards, Battery: passo 1, immagine 2 di 2
    • Flip the ThinkPad over so that it is upside down.
    • Slide the highlighted tab to the left.
    • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
  2. Disassembling IBM ThinkPad A30 Modem and Ethernet Cards, Modem and Ethernet Cards: passo 2, immagine 1 di 2 Disassembling IBM ThinkPad A30 Modem and Ethernet Cards, Modem and Ethernet Cards: passo 2, immagine 2 di 2
    • Remove the two 5.3mm cover screws.
    • Gently lift the cover.
  3. Disassembling IBM ThinkPad A30 Modem and Ethernet Cards: passo 3, immagine 1 di 1
    • Remove the four 9.1mm screws attached to the ethernet and modem cards.
  4. Disassembling IBM ThinkPad A30 Modem and Ethernet Cards: passo 4, immagine 1 di 3 Disassembling IBM ThinkPad A30 Modem and Ethernet Cards: passo 4, immagine 2 di 3 Disassembling IBM ThinkPad A30 Modem and Ethernet Cards: passo 4, immagine 3 di 3
    • When lifting the cards, be careful not to rip out the cables!
    • Gently lift the modem and ethernet cards.
    • Remove the cables that attach the modem and ethernet cards.
Conclusione
Alan
Membro da: 10/07/10
380 Reputazione
6 Guide realizzate
Cal Poly, Team 4-44, Amido Fall 2010 Membro di Cal Poly, Team 4-44, Amido Fall 2010
CPSU-AMIDO-F10S4G44
4 Membri
26 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,886
