Salta al contenuto principale
Disassembling IBM ThinkPad A30 Display Assembly
Cosa ti serve
  1. Disassembling IBM ThinkPad A30 Display Assembly, Battery: passo 1, immagine 1 di 2 Disassembling IBM ThinkPad A30 Display Assembly, Battery: passo 1, immagine 2 di 2
    • Flip the ThinkPad over so that it is upside down.
    • Slide the highlighted tab to the left.
    • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
  2. Disassembling IBM ThinkPad A30 Display Assembly, Hard Drive: passo 2, immagine 1 di 3 Disassembling IBM ThinkPad A30 Display Assembly, Hard Drive: passo 2, immagine 2 di 3 Disassembling IBM ThinkPad A30 Display Assembly, Hard Drive: passo 2, immagine 3 di 3
    • Remove the highlighted screw with a Phillips #1 screwdriver.
    • Pull the hard drive out.
  3. Disassembling IBM ThinkPad A30 Display Assembly, Upper Case: passo 3, immagine 1 di 1
    • Make sure the laptop is upside down and oriented in the direction shown.
    • Remove the six 16.7mm screws inside the circled holes.
  4. Disassembling IBM ThinkPad A30 Display Assembly: passo 4, immagine 1 di 1
    • Rotate the ThinkPad so that the hard drive bay is facing you.
    • Remove the black cover to reveal a 14.8mm screw.
    • Remove the uncovered screw with a Phillips #0 screwdriver.
  5. Disassembling IBM ThinkPad A30 Display Assembly: passo 5, immagine 1 di 2 Disassembling IBM ThinkPad A30 Display Assembly: passo 5, immagine 2 di 2
    • Flip the ThinkPad over and open the LCD panel.
    • Pry apart the keyboard with a plastic opening tool or with your fingers.
  6. Disassembling IBM ThinkPad A30 Display Assembly: passo 6, immagine 1 di 3 Disassembling IBM ThinkPad A30 Display Assembly: passo 6, immagine 2 di 3 Disassembling IBM ThinkPad A30 Display Assembly: passo 6, immagine 3 di 3
    • Be careful not to pull out the keyboard carelessly; there is a connector underneath it!
    • Lift the front end of the keyboard as shown.
    • Using your fingers, remove the black film cover.
  7. Disassembling IBM ThinkPad A30 Display Assembly: passo 7, immagine 1 di 3 Disassembling IBM ThinkPad A30 Display Assembly: passo 7, immagine 2 di 3 Disassembling IBM ThinkPad A30 Display Assembly: passo 7, immagine 3 di 3
    • Locate the connector attached to the motherboard.
    • Disconnect the ribbon cable by removing the connector.
  8. Disassembling IBM ThinkPad A30 Display Assembly: passo 8, immagine 1 di 2 Disassembling IBM ThinkPad A30 Display Assembly: passo 8, immagine 2 di 2
    • Lift and remove the keyboard.
    • Remove the two 5.6mm screws.
    • Remove the 16.7mm screw.
  9. Disassembling IBM ThinkPad A30 Display Assembly: passo 9, immagine 1 di 3 Disassembling IBM ThinkPad A30 Display Assembly: passo 9, immagine 2 di 3 Disassembling IBM ThinkPad A30 Display Assembly: passo 9, immagine 3 di 3
    • You will need to use a little force. Be wary of the tabs.
    • Pry off the upper case with your hands.
  10. Disassembling IBM ThinkPad A30 Display Assembly, Display Assembly: passo 10, immagine 1 di 1
    • Remove the 5.6mm screw that holds the LCD to the upper case.
  11. Disassembling IBM ThinkPad A30 Display Assembly: passo 11, immagine 1 di 3 Disassembling IBM ThinkPad A30 Display Assembly: passo 11, immagine 2 di 3 Disassembling IBM ThinkPad A30 Display Assembly: passo 11, immagine 3 di 3
    • Remove the 5.6mm screw on the left side of the three-pronged connector.
    • Remove the other two 16.7mm screws.
    • Lift and remove connector.
  12. Disassembling IBM ThinkPad A30 Display Assembly: passo 12, immagine 1 di 2 Disassembling IBM ThinkPad A30 Display Assembly: passo 12, immagine 2 di 2
    • Pull out the white tab connecting the LCD to the motherboard.
  13. Disassembling IBM ThinkPad A30 Display Assembly: passo 13, immagine 1 di 2 Disassembling IBM ThinkPad A30 Display Assembly: passo 13, immagine 2 di 2
    • Turn the laptop so that the back is facing you.
    • Remove the four 5.6mm long screws.
  14. Disassembling IBM ThinkPad A30 Display Assembly: passo 14, immagine 1 di 3 Disassembling IBM ThinkPad A30 Display Assembly: passo 14, immagine 2 di 3 Disassembling IBM ThinkPad A30 Display Assembly: passo 14, immagine 3 di 3
    • Place the laptop so that the LCD is facing you again.
    • Gently lift the LCD monitor up and out.
    • Remove the black plastic tab.
Conclusione
Jessica
Membro da: 10/06/10
162 Reputazione
7 Guide realizzate
Cal Poly, Team 4-44, Amido Fall 2010 Membro di Cal Poly, Team 4-44, Amido Fall 2010
CPSU-AMIDO-F10S4G44
4 Membri
26 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 12
Tutti i Tempi: 3,413
