Salta al contenuto principale
Disassembling IBM ThinkPad A30 CD Drive
  1. Disassembling IBM ThinkPad A30 CD Drive, Battery: passo 1, immagine 1 di 2 Disassembling IBM ThinkPad A30 CD Drive, Battery: passo 1, immagine 2 di 2
    • Flip the ThinkPad over so that it is upside down.
    • Slide the highlighted tab to the left.
    • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
  2. Disassembling IBM ThinkPad A30 CD Drive, CD Drive: passo 2, immagine 1 di 3 Disassembling IBM ThinkPad A30 CD Drive, CD Drive: passo 2, immagine 2 di 3 Disassembling IBM ThinkPad A30 CD Drive, CD Drive: passo 2, immagine 3 di 3
    • Hold the laptop in the same orientation as the picture. Then, locate the switch immediately above and to the left of the drive.
    • Slide the switch to the right. A black plastic tab will pop out.
    • Pull the plastic tab to expose the CD drive.
    • If there is a problem with your tab, whether it doesn't pop out or it doesn't expose the CD drive, please check the corresponding entry in the troubleshooting page.
  3. Disassembling IBM ThinkPad A30 CD Drive: passo 3, immagine 1 di 1
    • Carefully pull the CD drive out from the laptop.
Conclusione
Jessica
Membro da: 10/06/10
162 Reputazione
7 Guide realizzate
Cal Poly, Team 4-44, Amido Fall 2010 Membro di Cal Poly, Team 4-44, Amido Fall 2010
CPSU-AMIDO-F10S4G44
4 Membri
26 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 2,392
