Introduzione
Removing the back case is easy and snaps right off, giving you access to all the parts inside.
Parti
Nessuna parte richiesta.
Turn off and unplug the netbook before replacing the battery. Hold the netbook top-side down with the lid closed.
  • Turn off and unplug the netbook before replacing the battery.
  • Hold the netbook top-side down with the lid closed.
  • Slide the plastic battery release latches towards the lock symbols.
  • The left tab unlocks completely, but you will need to hold the right tab towards the lock symbol as you remove the battery.
Aggiungi Commento
Slide the battery out from the netbook.
  • Slide the battery out from the netbook.
Aggiungi Commento
Turn the netbook to view its edge.
  • Turn the netbook to view its edge.
  • Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
Aggiungi Commento
If the back case does not separate from the netbook easily, use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
  • If the back case does not separate from the netbook easily, use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
Aggiungi Commento
Pull the back case off from the front edge.
  • Pull the back case off from the front edge.
Aggiungi Commento
Conclusione
Altre 9 persone hanno completato questa guida.
Heather Freed
Membro da: 06/10/2012
570 Reputazione
8 Guide realizzate
Cal Poly, Team 9-17, Amido Fall 2012 Membro di Cal Poly, Team 9-17, Amido Fall 2012
CPSU-AMIDO-F12S9G17
3 Membri
8 Guide realizzate
Gracias!! esta guía fue muy util
Tony Ortega - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 26
Ultimi 30 Giorni: 159
Tutti i Tempi: 14,632
