Salta al contenuto principale
Disassembling General Electric Telephone 2-9710A Handset
Cosa ti serve
  1. Disassembling General Electric Telephone 2-9710A Handset, Phone Cord: passo 1, immagine 1 di 2 Disassembling General Electric Telephone 2-9710A Handset, Phone Cord: passo 1, immagine 2 di 2
    • Unplug the device before proceeding.
    • Using a plastic opening tool, remove the phone cord from the phone jack at the base of the headset.
    • To release the cable, gently press down on the top plastic tab of the connector.
  2. Disassembling General Electric Telephone 2-9710A Handset: passo 2, immagine 1 di 3 Disassembling General Electric Telephone 2-9710A Handset: passo 2, immagine 2 di 3 Disassembling General Electric Telephone 2-9710A Handset: passo 2, immagine 3 di 3
    • Remove the 7.5 mm screw.
    • Remove the screw cap.
    • Pull up the phone cord to remove it from the base.
  3. Disassembling General Electric Telephone 2-9710A Handset, General Electric Telephone 2-9710A Handset: passo 3, immagine 1 di 2 Disassembling General Electric Telephone 2-9710A Handset, General Electric Telephone 2-9710A Handset: passo 3, immagine 2 di 2
    • Remove the plastic cover with a plastic opening tool by gently sliding the tool underneath the plastic and pry the cover off.
  4. Disassembling General Electric Telephone 2-9710A Handset: passo 4, immagine 1 di 1
    • Remove the paper with a plastic opening tool by gently sliding the tool underneath and prying the paper away from the phone.
  5. Disassembling General Electric Telephone 2-9710A Handset: passo 5, immagine 1 di 2 Disassembling General Electric Telephone 2-9710A Handset: passo 5, immagine 2 di 2
    • Remove the rubber stopper with a plastic opening tool by gently sliding the tool underneath and pry away from the phone.
  6. Disassembling General Electric Telephone 2-9710A Handset: passo 6, immagine 1 di 2 Disassembling General Electric Telephone 2-9710A Handset: passo 6, immagine 2 di 2
    • Remove the two 2.1 mm screws with a Phillips #1 screwdriver.
  7. Disassembling General Electric Telephone 2-9710A Handset: passo 7, immagine 1 di 1
    • Pull apart the handset by pulling the top shell away from the other half of the phone.
  8. Disassembling General Electric Telephone 2-9710A Handset: passo 8, immagine 1 di 2 Disassembling General Electric Telephone 2-9710A Handset: passo 8, immagine 2 di 2
    • Remove 3 screws attaching the motherboard to shell.
    • Remove the 13 mm screw with a Philips #1 screwdriver.
    • Remove the two 13 mm screws with washers with a Philips #1 screwdriver.
  9. Disassembling General Electric Telephone 2-9710A Handset: passo 9, immagine 1 di 2 Disassembling General Electric Telephone 2-9710A Handset: passo 9, immagine 2 di 2
    • Slide the phone jack out from the shell by gently lifting up the female phone jack connector.
  10. Disassembling General Electric Telephone 2-9710A Handset: passo 10, immagine 1 di 1
    • Without removing the motherboard completely, pull up slightly and pivot the motherboard out of the shell.
    • Be careful not to pull the connectors out.
Conclusione
Alles Rebel
Membro da: 09/20/12
72 Reputazione
3 Guide realizzate
Cal Poly, Team 16-59, Forte Fall 2012 Membro di Cal Poly, Team 16-59, Forte Fall 2012
CPSU-FORTE-F12S16G59
4 Membri
17 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 24
Tutti i Tempi: 2,698
