Introduzione
This guide shows how to fully disassemble a Garmin Nuvi 1200 to replace the logic board.
Parti
Nessuna parte richiesta.
Remove to sticker on the back of the unit and then remove the two T5 scremws once this is done use a spudger to carefully pry off the silver cover.
  • Remove to sticker on the back of the unit and then remove the two T5 scremws once this is done use a spudger to carefully pry off the silver cover.
    • Once the tool is inserted it can slide around the entire device.
Aggiungi Commento
Remove four small T5 torx screws.
  • Remove four small T5 torx screws.
    • Be gentle, the screws are easily stripped.
Aggiungi Commento
Guida ai regali per la festa del papà
Facciamo onore non solo ai nostri padri — festeggiamo tutti i mentori che ci hanno insegnato a riparare.
Facciamo onore a chi ci ha insegnato a riparare.
Lift cover off of unit. Be careful not to lose small rubber piece on the bottom right corner.
  • Lift cover off of unit.
  • Be careful not to lose small rubber piece on the bottom right corner.
Aggiungi Commento
Disconnect ribbon cable from logic board.
  • Disconnect ribbon cable from logic board.
Aggiungi Commento
Remove two T5 torx screws holding down logic board.
  • Remove two T5 torx screws holding down logic board.
  • Disconnect battery.
Aggiungi Commento
Gently lift the logic board out of the unit
  • Gently lift the logic board out of the unit
    • Be careful not to damage the battery connector on the top of the unit.
Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
Zachary Landau
Membro da: 28/11/2010
178 Reputazione
1 Guida realizzata
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 4,913
