To remove the battery from the casing, grab the front panel and back panel with opposite hands (as shown).  The back panel is the same as the battery. With your index finger, push in the button on the bottom of the battery to release it. Pull the battery away from the phone.
  • To remove the battery from the casing, grab the front panel and back panel with opposite hands (as shown). The back panel is the same as the battery.
  • With your index finger, push in the button on the bottom of the battery to release it.
  • Pull the battery away from the phone.
Aggiungi Commento
After removing the battery, the front phone casing becomes accessible. Locate the two star-shaped T6 screws on the bottom end of the rear of the phone, underneath the battery, as indicated by the red circles. Remove these two screws using the Torx T6 Screwdriver.
  • After removing the battery, the front phone casing becomes accessible.
  • Locate the two star-shaped T6 screws on the bottom end of the rear of the phone, underneath the battery, as indicated by the red circles.
  • Remove these two screws using the Torx T6 Screwdriver.
Aggiungi Commento
Locate the top two U-shaped screws on the back of the phone, as shown by the red circles. Remove these two screws with a SP 2.6 screw driver. Note:  Remove gray plastic grommets with screws.
  • Locate the top two U-shaped screws on the back of the phone, as shown by the red circles.
  • Remove these two screws with a SP 2.6 screw driver.
  • Note: Remove gray plastic grommets with screws.
Aggiungi Commento
Grab opposite panels of the phone casing and carefully open and pull apart the phone, as shown in the image. Note:  Be careful not to damage the circuit board and components as you as open the casing.
  • Grab opposite panels of the phone casing and carefully open and pull apart the phone, as shown in the image.
  • Note: Be careful not to damage the circuit board and components as you as open the casing.
Aggiungi Commento
Locate the circuit board on the rear side of the front phone casing (right side of image).
  • Locate the circuit board on the rear side of the front phone casing (right side of image).
  • Locate the mounting screws (indicated by red circles), which attach the board to the rear side of the front phone casing.
Aggiungi Commento
Using the SP2.6 u-shaped screw driver in one hand, loosen and remove both center screws.  Hold the back part of the screw with the metal tweezers. Using the SP2.6 u-shaped screw driver in one hand, loosen and remove both center screws.  Hold the back part of the screw with the metal tweezers. Using the SP2.6 u-shaped screw driver in one hand, loosen and remove both center screws.  Hold the back part of the screw with the metal tweezers.
  • Using the SP2.6 u-shaped screw driver in one hand, loosen and remove both center screws. Hold the back part of the screw with the metal tweezers.
Aggiungi Commento
Completely remove the two center screw as shown. Note:  the hand not holding the screw driver is holding the back part of the screw and the panel in place.
  • Completely remove the two center screw as shown.
  • Note: the hand not holding the screw driver is holding the back part of the screw and the panel in place.
Aggiungi Commento
Locate the final screw at the top of the phone near the antenna, as shown by the red circle. Using the U-shaped screw driver, remove the top screw.
  • Locate the final screw at the top of the phone near the antenna, as shown by the red circle.
  • Using the U-shaped screw driver, remove the top screw.
Aggiungi Commento
With one hand on the circuit board and one hand on the phone casing, carefully pull apart the circuit board from the front panel casing. With one hand on the circuit board and one hand on the phone casing, carefully pull apart the circuit board from the front panel casing.
  • With one hand on the circuit board and one hand on the phone casing, carefully pull apart the circuit board from the front panel casing.
Aggiungi Commento
Conclusione
Niccolas Tones
Membro da: 09/03/2012
55 Reputazione
18 Guide realizzate
Clemson, Team 1-1, Benson Spring 2012 Membro di Clemson, Team 1-1, Benson Spring 2012
CLEM-BENSON-S12S1G1
3 Membri
21 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,120
