Introduzione
Before starting, please:
- make sure nothing is attached (such as AC adapter, USB, VGA, audio jack).
- remove any inserted SD card.
Cosa ti serve
Slide the switch on the bottom of the laptop until the battery pops out.
Once the battery pops out, you can remove it.
Using a pair of tweezers, remove the two rear rubber feet to expose two hidden screws.
Remove ten 3 mm screws in the battery compartment using a Phillips #00 screwdriver.
Remove two 4.5 mm screws under the rubber feet using a Phillips #00 screwdriver.
Altre 2 persone hanno completato questa guida.
