Introduzione
Wireless module in your way? Move it out!
Parti
Nessuna parte richiesta.
Find the battery and the battery tabs located on the bottom of the Compaq Mini. Find the battery and the battery tabs located on the bottom of the Compaq Mini.
  • Find the battery and the battery tabs located on the bottom of the Compaq Mini.
Aggiungi Commento
Push the tabs inward and slide the battery out. Push the tabs inward and slide the battery out. Push the tabs inward and slide the battery out.
  • Push the tabs inward and slide the battery out.
Aggiungi Commento
Find and remove the two screws on the bottom of your Compaq Mini covering the memory compartment. Note that the screws are attached to the panel.
  • Find and remove the two screws on the bottom of your Compaq Mini covering the memory compartment.
    • Note that the screws are attached to the panel.
Aggiungi Commento
Push out side tabs.
  • Push out side tabs.
Aggiungi Commento
Remove the rubber pads located on the corners of your Compaq Mini. There may be junk underneath it. This is residue left from the glue that held on the rubber pad. Just scrape it away to find the screw.
  • Remove the rubber pads located on the corners of your Compaq Mini.
  • There may be junk underneath it. This is residue left from the glue that held on the rubber pad. Just scrape it away to find the screw.
Aggiungi Commento
Unscrew all the corner screws. There are four total, one under each rubber pad. Unscrew all the corner screws. There are four total, one under each rubber pad.
  • Unscrew all the corner screws. There are four total, one under each rubber pad.
Aggiungi Commento
Unscrew the screw for the bottom case located in the RAM compartment. Unscrew the screw for the bottom case located in the RAM compartment.
  • Unscrew the screw for the bottom case located in the RAM compartment.
Falta um passo, pois nos modelos COMPAQ MINI 110, existe um parafuso que segura o teclado, que se encontra bem escondido dentro da cavidade que encaixa a bateria.
Amilcar Correia - Replica
Remove the three screws in the silver tabs at the back of the keyboard. The red circles show where they are located at the back of the base under the screen. Remove the three screws in the silver tabs at the back of the keyboard. The red circles show where they are located at the back of the base under the screen.
  • Remove the three screws in the silver tabs at the back of the keyboard. The red circles show where they are located at the back of the base under the screen.
3 screws in red circles are actually on metal tabs in the battery compartment, 1 deeper than the other 2. There is a keyboard symbol for each of the 3 screws.
Step 8B: Lift out keyboard by pushing upwards on the 2 accessible metal tabs. This is the most difficult step. Lack of Quality Control during assembly may prevent the kevboard from lifting out without breaking!!
John - Replica
This step may be performed after battery removal. Use care when removing ribbon cable: the white clips holding the black plastic "keeper" are fragile. Reassembly possible without white clips; however, jostling may cause the ribbon to come free.
Jason L - Replica
Remove the three screws.
  • Remove the three screws.
Aggiungi Commento
Pull up on the tab. Pull up on the tab.
  • Pull up on the tab.
Aggiungi Commento
Remove the eight screws from the plastic top cover.
  • Remove the eight screws from the plastic top cover.
Aggiungi Commento
Pry up the top plastic cover using a spudger. Under the screen there are two tabs that need to be pushed in. Under the screen there are two tabs that need to be pushed in.
  • Pry up the top plastic cover using a spudger.
    • Under the screen there are two tabs that need to be pushed in.
Aggiungi Commento
Careful lifting up the cover because the track pad is still attached. Remove the cable by pulling it up.
  • Careful lifting up the cover because the track pad is still attached.
  • Remove the cable by pulling it up.
Aggiungi Commento
Remove the two screws holding the module in place.
  • Remove the two screws holding the module in place.
Aggiungi Commento
Detach the two wires.
  • Detach the two wires.
Aggiungi Commento
Just pull it out.
  • Just pull it out.
Aggiungi Commento
Conclusione
alea
Membro da: 06/10/2010
1.242 Reputazione
19 Guide realizzate
Cal Poly, Team 22-2, Maness Fall 2010 Membro di Cal Poly, Team 22-2, Maness Fall 2010
CPSU-MANESS-F10S22G2
6 Membri
20 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 3,901
