Salta al contenuto principale
Disassembling Circo Monkey Alarm Clock Clock Face
Cosa ti serve
  1. Disassembling Circo Monkey Alarm Clock Clock Face, Disassembling Circo Monkey Alarm Clock Clock Face: passo 1, immagine 1 di 3 Disassembling Circo Monkey Alarm Clock Clock Face, Disassembling Circo Monkey Alarm Clock Clock Face: passo 1, immagine 2 di 3 Disassembling Circo Monkey Alarm Clock Clock Face, Disassembling Circo Monkey Alarm Clock Clock Face: passo 1, immagine 3 di 3
    • Grasp the plastic cover and carefully pull straight back so that the clock cover dislodges from its housing.
    • If any additional assistance is required for this step, it is recommended to use the plastic opening tool to help pry the edges of the cover simultaneously or a suction cup if you cannot grip the rim.
  2. Disassembling Circo Monkey Alarm Clock Clock Face: passo 2, immagine 1 di 1
    • Using your fingers, grasp the point where the hands of the clock meet in the center and pull straight back until they dislodge from the motor.
    • Be sure that you remove all three hands as well as the pin that connects them in this one step. This component should come out as a single piece.
Conclusione
Devin Gooding
Membro da: 01/20/15
110 Reputazione
1 Guida realizzata
USF Tampa, Team 19-1, Blackwell Winter 2015 Membro di USF Tampa, Team 19-1, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G1
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 517
