Introduzione
The LCD display can be removed and replaced if it is cracked or broken.
Parti
Nessuna parte richiesta.
Remove the 2 screws(2.41mm long) on the side of the camera next to the LCD screen. Remove the 2 screws(4.08mm) on the other side.  One is located under the rubber USB flap. Remove the last screw(2.59mm) located on the bottom of the camera.
  • Remove the 2 screws(2.41mm long) on the side of the camera next to the LCD screen.
  • Remove the 2 screws(4.08mm) on the other side. One is located under the rubber USB flap.
  • Remove the last screw(2.59mm) located on the bottom of the camera.
  • Slowly pull the back cover of the camera.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Remove the screws(2.88mm) at the top right corner and bottom left corner of the LCD screen. Disconnect the ribbons connecting the screen to the camera. Remove the screen by lifting it off.
  • Remove the screws(2.88mm) at the top right corner and bottom left corner of the LCD screen.
  • Disconnect the ribbons connecting the screen to the camera.
  • Remove the screen by lifting it off.
Aggiungi Commento
Conclusione
Ben Tupas
Membro da: 13/01/2011
317 Reputazione
3 Guide realizzate
Cal Poly, Team 13-3, Forte Winter 2011 Membro di Cal Poly, Team 13-3, Forte Winter 2011
CPSU-FORTE-W11S13G3
5 Membri
8 Guide realizzate
Hm. "Disconnect the ribbons" resulted in a torn ribbon, and so a dead camera, I think. This also doesn't say how to take the LCD screen out of its frame. Alas.
Maelduin - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,145
