Introduzione
How to remove the outer casing of your Canon PowerShot SD850 IS.
Parti
Nessuna parte richiesta.
Using your fingernail, slide the light gray tab towards edge of camera. Slide the light gray door and pull up to open the door. In the camera shown in the photos, there is not a Memory Card or Battery.
  • Using your fingernail, slide the light gray tab towards edge of camera.
  • Slide the light gray door and pull up to open the door.
    • In the camera shown in the photos, there is not a Memory Card or Battery.
  • Both Battery and Memory Card slots should be visible.
Aggiungi Commento
Use your fingernail and slide the small brown tab towards the edge of the camera. The battery will pop up.
  • Use your fingernail and slide the small brown tab towards the edge of the camera.
  • The battery will pop up.
  • Pull battery straight out of battery holder.
  • When putting the battery back in, make sure it the battery is oriented so the terminals connect.
Aggiungi Commento
Remove the following 4 screws: Two 2.8 mm Phillips #00 at the bottom of the camera.
  • Remove the following 4 screws:
    • Two 2.8 mm Phillips #00 at the bottom of the camera.
    • Two 2.75 mm Phillips #00 on the opposite side of the wrist strap.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Open the A/V OUT DIGITAL flap on the side of the wrist strap. Remove the 2.75 mm Phillips #00 under the A/V OUT DIGITAL flap on the side of the wrist strap. Remove the 2.75 mm Phillips #00 under the A/V OUT DIGITAL flap on the side of the wrist strap.
  • Open the A/V OUT DIGITAL flap on the side of the wrist strap.
  • Remove the 2.75 mm Phillips #00 under the A/V OUT DIGITAL flap on the side of the wrist strap.
Aggiungi Commento
On the bottom of the camera, use your fingernail to slide the light gray tab towards the edge of the camera. Slide light gray door and pull up to open the door.
  • On the bottom of the camera, use your fingernail to slide the light gray tab towards the edge of the camera.
  • Slide light gray door and pull up to open the door.
  • Remove the 8.35 mm Phillips #00 next to the brown tab that holds the battery.
Aggiungi Commento
Gently pull the front cover straight out from the camera. This will expose the wiring on the front of the camera. Gently pull the front cover straight out from the camera. This will expose the wiring on the front of the camera.
  • Gently pull the front cover straight out from the camera. This will expose the wiring on the front of the camera.
Aggiungi Commento
Remove the 2.75 mm Phillips #00 next to A/V OUT DIGITAL.
  • Remove the 2.75 mm Phillips #00 next to A/V OUT DIGITAL.
Aggiungi Commento
Slide the back casing (with the screen protector) off to reveal the LCD and back wiring.
  • Slide the back casing (with the screen protector) off to reveal the LCD and back wiring.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Peter Tran
Membro da: 06/10/2010
225 Reputazione
6 Guide realizzate
Cal Poly, Team 20-7, Maness Fall 2010 Membro di Cal Poly, Team 20-7, Maness Fall 2010
CPSU-MANESS-F10S20G7
6 Membri
7 Guide realizzate
Had to exchange a battery/SD card cover on an Ixus970IS. This guide very helpful showing the way due to similar layout of the Ixus and the PS850IS! Thanx a lot! :-)
KBK Copenhagen DK
Keld Baden-Kristensen - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 3,731
