Introduzione
Use this guide to remove the LCD screen.
Parti
Nessuna parte richiesta.
Remove wrist strap and battery. Remove wrist strap and battery.
  • Remove wrist strap and battery.
Aggiungi Commento
Remove 2 screws from each side of the camera (4 total, 0.102 in). Remove 2 screws from the bottom on the camera (0.138 in). Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
  • Remove 2 screws from each side of the camera (4 total, 0.102 in).
  • Remove 2 screws from the bottom on the camera (0.138 in).
  • Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
Aggiungi Commento
Gently pull off the front cover. The plate on the side should come off. Gently pull off the back cover.
  • Gently pull off the front cover.
  • The plate on the side should come off.
  • Gently pull off the back cover.
Aggiungi Commento
The cases should now be removed.
  • The cases should now be removed.
This can be a bit tricky when reassembling. All of the little tabs around the edge need to snap into their proper places, and there are three cover pieces to manage. Plus, you need to make sure that the camera/video/playback switch is properly engaged with its slider on the circuit board, otherwise you'll need to raise the back panel and reposition everything again.
Craig Bonsignore - Replica
oh yes , i agree lol
elbala80 -
Remove the top-left screw above the LCD screen (0.100 in). Remove the C-shaped plate from the side of the LCD screen.
  • Remove the top-left screw above the LCD screen (0.100 in).
  • Remove the C-shaped plate from the side of the LCD screen.
Aggiungi Commento
Remove the screw from the top-right of the LCD screen (0.098 in). Remove the L-shaped bar from the right of the LCD screen.
  • Remove the screw from the top-right of the LCD screen (0.098 in).
  • Remove the L-shaped bar from the right of the LCD screen.
I used this guide for a blue "made in china" version of this camera, as well as a silver "made in japan" version. The L-shaped brackets on either side of the LCD were much easier to remove for the blue one, but I was able to get them out for the silver one also with some additional coaxing. There were more pronounced tabs/notches securing the brackets to the adjacent frame on the silver one.
Use the spudger to remove the L-shaped bar from the left-side of the LCD screen. Use the spudger to remove the L-shaped bar from the left-side of the LCD screen.
  • Use the spudger to remove the L-shaped bar from the left-side of the LCD screen.
Aggiungi Commento
Use tweezers to remove the connector ribbon from the top-left corner above the LCD screen.
  • Use tweezers to remove the connector ribbon from the top-left corner above the LCD screen.
  • Be gentle. This ribbon should stay attached to the screen.
There is a hole in the reinforced "plug" end of the LCD cable shown in Step 8. You can use a dental-type pick to remove and replace the plug easily.
Edward Pinnell - Replica
Use a spudger to lift the connector lock (black flap) at the end of the larger LCD connector ribbon on the front side of the camera. Use the tweezers to lift this ribbon. Use the tweezers to gently peel this ribbon from the one underneath it.
  • Use a spudger to lift the connector lock (black flap) at the end of the larger LCD connector ribbon on the front side of the camera.
  • Use the tweezers to lift this ribbon.
  • Use the tweezers to gently peel this ribbon from the one underneath it.
Aggiungi Commento
The LCD screen should now be removed.
  • The LCD screen should now be removed.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Tyler Grossheim
Membro da: 25/01/2011
1.359 Reputazione
6 Guide realizzate
Cal Poly, Team 3-32, Regan Winter 2011 Membro di Cal Poly, Team 3-32, Regan Winter 2011
CPSU-REGAN-W11S3G32
3 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 3,279
