Introduzione
This guide describes the steps to opening the case.
Parti
Nessuna parte richiesta.
Remove 2 screws from each side of the amplifier.
  • Remove 2 screws from each side of the amplifier.
Aggiungi Commento
Remove 2 screws on rear of device. Slide top cover up and back from main case.
  • Remove 2 screws on rear of device. Slide top cover up and back from main case.
Aggiungi Commento
Remove 3 screws on bottom of case. Remove 13 screws on rear panel.
  • Remove 3 screws on bottom of case.
  • Remove 13 screws on rear panel.
    • Do not move the rear panel too far, as the power cord is still connected.
Aggiungi Commento
Using a pair of pliers, squeeze the retainer for the power cord as shown and pull it toward the external side the panel.
  • Using a pair of pliers, squeeze the retainer for the power cord as shown and pull it toward the external side the panel.
  • It may require some wiggling, but it should slip out of the hole and then off of the cord.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Colby
Membro da: 15/04/2010
284 Reputazione
3 Guide realizzate
Cal Poly, Team 28-36, Regan Spring 2010 Membro di Cal Poly, Team 28-36, Regan Spring 2010
CPSU-REGAN-S10S28G36
4 Membri
3 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 3,375
