Parti
Nessuna parte richiesta.
Remove the battery, then unscrew the 7 3 mm Phillips screws behind the battery. Make sure they go in separate, organized piles. Unscrew the 2 4 mm Phillips head screws by the battery. Unscrew the 2 4 mm Phillips head screws by the battery.
  • Remove the battery, then unscrew the 7 3 mm Phillips screws behind the battery. Make sure they go in separate, organized piles.
  • Unscrew the 2 4 mm Phillips head screws by the battery.
Aggiungi Commento
Remove the panel above the keyboard with a plastic spudger.
  • Remove the panel above the keyboard with a plastic spudger.
Aggiungi Commento
Once the panel is removed, use the spudger to pry out the keyboard.
  • Once the panel is removed, use the spudger to pry out the keyboard.
  • Do not fully remove, for the keyboard is still attached to the ribbon cable.
Aggiungi Commento
Detach the ribbon cable from the keyboard by pulling the end of the ribbon cable that is attached inside of the laptop. Be sure to detach from the root rather than from near the middle. It should slide out with ease.
  • Detach the ribbon cable from the keyboard by pulling the end of the ribbon cable that is attached inside of the laptop.
  • Be sure to detach from the root rather than from near the middle. It should slide out with ease.
  • Now you can fully remove the keyboard from the laptop.
Aggiungi Commento
Place your fingers or a spudger between the front panel and the rest of the laptop.
  • Place your fingers or a spudger between the front panel and the rest of the laptop.
  • Pull upwards gently to detach the side you are grabbing.
  • Repeat on the other side until the panel easily peels off the laptop.
Aggiungi Commento
The touchpad should be loosely attached to the rest of the laptop by a ribbon cable. The touchpad should be loosely attached to the rest of the laptop by a ribbon cable.
  • The touchpad should be loosely attached to the rest of the laptop by a ribbon cable.
Aggiungi Commento
Gently pull the ribbon cable out of its socket attached to the touchpad.
  • Gently pull the ribbon cable out of its socket attached to the touchpad.
  • You are now able to remove the touchpad.
Aggiungi Commento
Unscrew the 3 13 mm Phillips screws on the surface of the panel.
  • Unscrew the 3 13 mm Phillips screws on the surface of the panel.
  • Unscrew the 4 mm Phillips screw beneath the panel.
Aggiungi Commento
There are many different types of screws in this step so make sure to arrange the screws by their different sizes. Unscrew the six 17 mm Phillips head screws on the stands on the back and the 2 "A" screws of the same size adjacent to the stands. Unscrew the two C Phillips head screws on the hard drive panel. There is also one more C screw in the upper right corner of the laptop as shown.
  • There are many different types of screws in this step so make sure to arrange the screws by their different sizes.
  • Unscrew the six 17 mm Phillips head screws on the stands on the back and the 2 "A" screws of the same size adjacent to the stands.
  • Unscrew the two C Phillips head screws on the hard drive panel. There is also one more C screw in the upper right corner of the laptop as shown.
  • Unscrew the eight 8mm lock phillips screws and the screws along the outside of the laptop.
  • Unscrew the three 3mm E Phillips screw and the one 3mm D Phillips screw.
  • Unscrew the 5mm Phillips head screw that lies just above the D screw.
Aggiungi Commento
Unscrew the two 8 mm Phillips screws beneath the hard drive panel.
  • Unscrew the two 8 mm Phillips screws beneath the hard drive panel.
  • After finishing this step, flip the laptop over.
Aggiungi Commento
Everything should now be loose enough for you to start removing the panel.
  • Everything should now be loose enough for you to start removing the panel.
  • Do not fully remove the panel, for there are still ribbons attached on the inside.
Aggiungi Commento
Carefully remove the ribbons from the base.
  • Carefully remove the ribbons from the base.
  • Then you can lift the panel to access the components beneath.
Aggiungi Commento
Conclusione
Nolan Schock
Membro da: 14/04/2014
501 Reputazione
5 Guide realizzate
Cal Poly, Team 13-29, Maness Spring 2014 Membro di Cal Poly, Team 13-29, Maness Spring 2014
CPSU-MANESS-S14S13G29
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 282
