Introduzione
How to disassemble the charger unit.
Slide the plug to release from the transformer unit
  • Slide the plug to release from the transformer unit
Aggiungi Commento
Slip a knife blade into the seam on one of the long edges. It should go in a fair way. Lever the lid upwards. It requires quite a bit of force to release. Be careful as the outer casing is flimsy and it will be deformed.
  • Slip a knife blade into the seam on one of the long edges. It should go in a fair way. Lever the lid upwards. It requires quite a bit of force to release. Be careful as the outer casing is flimsy and it will be deformed.
Aggiungi Commento
Once the lid comes off you can slide out the internals.
  • Once the lid comes off you can slide out the internals.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
ehfb
Membro da: 17/02/2015
61 Reputazione
1 Guida realizzata
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 50
Tutti i Tempi: 3,556
