Introduzione
Disassembly
1. Flip toaster over.
2. Locate four phillips screws on the bottom of the toaster.
3. Loosen and remove.
4. Sides will pop out once screws are removed.
  • 1. Flip toaster over.
Aggiungi Commento
  • 2. Locate four phillips screws on the bottom of the toaster.
Aggiungi Commento
3. Loosen and remove using a Phillips head screwdriver
  • 3. Loosen and remove using a Phillips head screwdriver
Aggiungi Commento
  • 4. Sides will pop out once screws are removed.
Aggiungi Commento
Conclusione
Carlos
Membro da: 23/07/2013
101 Reputazione
1 Guida realizzata
Hi Carlos,
Before removing the cover I need to remove the PUSH LEVER.
Please forward instructions on HOW TO REMOVE THE PUSH LEVER.
Thank you.
Earle
earleb - Replica
I Disassembled, cleaned and put it back together.  However the purpose of the exercise was to fix the browning feature or timing issue.  the little plastic bit that goes from the browning turn knob does not function.  So the push knob does not stay down.  This results in having to hold the push knob down till the toast is done to my satisfaction.  The little plastic bit does not connect properly to the PCB or whatever else it is connected to, and so the push knob on the side of the toaster does not stay down.. Allan
Allan Rodrigues - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 536
