Introduzione
This guide helps you to upgrade or replace your wireless card to a new Wi-Fi standard if you have determined that the reason your wireless internet is not working is because of a hardware issue with the card.
Parti
Nessuna parte richiesta.
Turn the computer upside down with the battery facing you.
  • Turn the computer upside down with the battery facing you.
  • Turn the computer off and disconnect the charging cable from the computer.
  • Failure to unplug the charging cable may result in electric shock.
Aggiungi Commento
Push the switch as far to the right as possible to unlock the battery.
  • Push the switch as far to the right as possible to unlock the battery.
Aggiungi Commento
Remove the battery using two hands and pull it away from the computer. Remove the battery using two hands and pull it away from the computer.
  • Remove the battery using two hands and pull it away from the computer.
Aggiungi Commento
Unscrew the two 4.7mm Phillips #1 screws on the bottom panel of the laptop.
  • Unscrew the two 4.7mm Phillips #1 screws on the bottom panel of the laptop.
    • Two 4.7mm Philips #1 screws
Aggiungi Commento
Lift the panel up from the indented area. This indent should provide enough grip to remove the panel with ease.
  • Lift the panel up from the indented area.
  • This indent should provide enough grip to remove the panel with ease.
Aggiungi Commento
Remove the single 3.9mm Phillips  #1 screw in the upper right corner of the wireless card.
  • Remove the single 3.9mm Phillips #1 screw in the upper right corner of the wireless card.
    • One 3.9mm Phillips #1 screw
Aggiungi Commento
Lift the card out at an angle and carefully remove it.
  • Lift the card out at an angle and carefully remove it.
Aggiungi Commento
Use a spudger to carefully disconnect the antenna cables from the card by prying them straight up off the board. It's best to use an ESD-safe tool, such as a nylon spudger, rather than the metal spudger shown in the photo.
  • Use a spudger to carefully disconnect the antenna cables from the card by prying them straight up off the board.
    • It's best to use an ESD-safe tool, such as a nylon spudger, rather than the metal spudger shown in the photo.
  • Note the order of colors for the antenna cables indicated on the card.
Aggiungi Commento
Conclusione
Jase Sasaki
Membro da: 22/01/2015
694 Reputazione
5 Guide realizzate
Cal Poly, Team 18-4, Maness Winter 2015 Membro di Cal Poly, Team 18-4, Maness Winter 2015
CPSU-MANESS-W15S18G4
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,042
