Introduzione
Memory modules allow computers to store electronic memory for users to access at a later time. This guide will show you how to install new memory modules on the Dell XPS 720 H2C, as well as how to reseat the current memory modules on the computer. The procedure is simple and requires minimal disassembly.
Strumenti
Nessun attrezzo richiesto.
Parti
Nessuna parte richiesta.
Remove the cover panel on the side of the computer by pulling out the latch on the back panel and pulling the panel downwards towards the ground. Remove the cover panel on the side of the computer by pulling out the latch on the back panel and pulling the panel downwards towards the ground.
  • Remove the cover panel on the side of the computer by pulling out the latch on the back panel and pulling the panel downwards towards the ground.
Aggiungi Commento
The memory modules are located directly above the XPS processor and are attached to the motherboard. There are notches securing the memory modules onto the motherboard. Push down and outward on the both notches to release each memory module from the motherboard.
  • The memory modules are located directly above the XPS processor and are attached to the motherboard.
  • There are notches securing the memory modules onto the motherboard.
  • Push down and outward on the both notches to release each memory module from the motherboard.
Aggiungi Commento
Carefully remove each memory module from its slot.
  • Carefully remove each memory module from its slot.
  • If you are reseating the memory modules, this is the time to clean them and make sure there isn't any dust build up on the surface.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Alexis Cervantes
Membro da: 21/04/2013
279 Reputazione
2 Guide realizzate
Cal Poly, Team 4-16, Maness Spring 2013 Membro di Cal Poly, Team 4-16, Maness Spring 2013
CPSU-MANESS-S13S4G16
3 Membri
3 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 877
