Salta al contenuto principale
Dell XPS 15 9570 Fan Replacement
Cosa ti serve
  1. Dell XPS 15 9570 Fan Replacement, Base Cover: passo 1, immagine 1 di 1
    • Make sure your device is powered off and unplugged before starting
    • Flip the device over so the base cover of the computer is facing upwards.
  2. Dell XPS 15 9570 Fan Replacement: passo 2, immagine 1 di 3 Dell XPS 15 9570 Fan Replacement: passo 2, immagine 2 di 3 Dell XPS 15 9570 Fan Replacement: passo 2, immagine 3 di 3
    • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
  3. Dell XPS 15 9570 Fan Replacement: passo 3, immagine 1 di 2 Dell XPS 15 9570 Fan Replacement: passo 3, immagine 2 di 2
    • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
  4. Dell XPS 15 9570 Fan Replacement: passo 4, immagine 1 di 1
    • Lift the back cover off of the device.
  5. Dell XPS 15 9570 Fan Replacement, Battery: passo 5, immagine 1 di 1
    • Using the Phillips #00 screwdriver, remove the four 4 mm screws holding the battery in place.
  6. Dell XPS 15 9570 Fan Replacement: passo 6, immagine 1 di 1
    • Use the iFixit opening tool to disconnect the battery connector from the motherboard.
  7. Dell XPS 15 9570 Fan Replacement: passo 7, immagine 1 di 1
    • With your hands, pick up and remove the battery from the system.
  8. Dell XPS 15 9570 Fan Replacement, Fan: passo 8, immagine 1 di 2 Dell XPS 15 9570 Fan Replacement, Fan: passo 8, immagine 2 di 2
    • Use the Phillips #00 screwdriver to remove the two 4 mm screws securing the grey display cable bracket.
  9. Dell XPS 15 9570 Fan Replacement: passo 9, immagine 1 di 1
    • Using the Phillips #00 screwdriver, remove the 4 mm screw at the back right corner of the fan.
  10. Dell XPS 15 9570 Fan Replacement: passo 10, immagine 1 di 2 Dell XPS 15 9570 Fan Replacement: passo 10, immagine 2 di 2
    • Disconnect the fan cable on the left of the fan and on the right side from the RAM, using the opening tool.
  11. Dell XPS 15 9570 Fan Replacement: passo 11, immagine 1 di 1
    • Lift the right fan off of the device.
    • Repeat steps 8-11 to remove the left fan from the system board.
    • The left fan is fixed with two 4 mm screws. Make sure you have removed them if the fan does not come off easily.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 13
Ultimi 7 Giorni: 46
Ultimi 30 Giorni: 184
Tutti i Tempi: 5,083
