Salta al contenuto principale
Dell XPS 15 9510 SSD Replacement
Cosa ti serve
  1. Dell XPS 15 9510 SSD Replacement, Rear Panel: passo 1, immagine 1 di 1
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
  2. Dell XPS 15 9510 SSD Replacement: passo 2, immagine 1 di 1
    • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
    • Wedge the case apart with a nylon spudger.
    • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
    • Slide spudger along each side of the laptop
  3. Dell XPS 15 9510 SSD Replacement: passo 3, immagine 1 di 1
    • Lift the back panel of the laptop off and set it aside.
  4. Dell XPS 15 9510 SSD Replacement, SSD: passo 4, immagine 1 di 2 Dell XPS 15 9510 SSD Replacement, SSD: passo 4, immagine 2 di 2
    • Remove the single screw from the left side of the SSD using a Phillips #00 screwdriver.
    • The SSD is spring-released; it will pop up after removing the screw.
  5. Dell XPS 15 9510 SSD Replacement: passo 5, immagine 1 di 1
    • Use your fingers to carefully remove the SSD from the laptop.
Conclusione
Altre 3 persone hanno completato questa guida.
Austin Sa
Membro da: 03/30/22
432 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 61
Tutti i Tempi: 3,517
