Salta al contenuto principale
Dell Venue 7 Rear Facing Camera Replacement
Cosa ti serve
  1. Dell Venue 7 Rear Facing Camera Replacement, Rear Case: passo 1, immagine 1 di 2 Dell Venue 7 Rear Facing Camera Replacement, Rear Case: passo 1, immagine 2 di 2
    • Use a spudger or your fingers to pry off the back case.
    • If your case is badly damaged, use caution because the fragments may be sharp.
  2. Dell Venue 7 Rear Facing Camera Replacement, Battery: passo 2, immagine 1 di 1
    • Gently disconnect the battery from the motherboard using your fingers or a pair of tweezers.
  3. Dell Venue 7 Rear Facing Camera Replacement: passo 3, immagine 1 di 1
    • Remove the battery by pulling it from the edges and carefully peeling it off of the base.
    • There is adhesive keeping the battery in place, so don't be afraid to use a little extra force.
    • Do not bend or warp the battery in any way as it can be a fire hazard.
  4. Dell Venue 7 Rear Facing Camera Replacement, Rear Facing Camera: passo 4, immagine 1 di 1
    • Use a spudger to disconnect the camera from the motherboard.
  5. Dell Venue 7 Rear Facing Camera Replacement: passo 5, immagine 1 di 1
    • Remove the camera from the device.
Conclusione
USF Tampa, Team 11-4, Blackwell Winter 2015 Membro di USF Tampa, Team 11-4, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G4
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 452
