Salta al contenuto principale
Dell Optiplex SX280 Lower Fan Replacement
Cosa ti serve
  1. Dell Optiplex SX280 Lower Fan Replacement, Panel Cover: passo 1, immagine 1 di 1
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Dell Optiplex SX280 Lower Fan Replacement: passo 2, immagine 1 di 2 Dell Optiplex SX280 Lower Fan Replacement: passo 2, immagine 2 di 2
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
  3. Dell Optiplex SX280 Lower Fan Replacement: passo 3, immagine 1 di 2 Dell Optiplex SX280 Lower Fan Replacement: passo 3, immagine 2 di 2
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
  4. Dell Optiplex SX280 Lower Fan Replacement, Lower Fan: passo 4, immagine 1 di 2 Dell Optiplex SX280 Lower Fan Replacement, Lower Fan: passo 4, immagine 2 di 2
    • Remove the large blue cover from the computer. There are no screws or tabs holding it in place.
  5. Dell Optiplex SX280 Lower Fan Replacement: passo 5, immagine 1 di 1
    • Remove the power supply by pressing the release tab. It is distinguished by the black, red, green, and yellow wires.
  6. Dell Optiplex SX280 Lower Fan Replacement: passo 6, immagine 1 di 2 Dell Optiplex SX280 Lower Fan Replacement: passo 6, immagine 2 di 2
    • Remove the rubber grommets from the base of the fan. The iFixit Opening tool may be useful in this step.
  7. Dell Optiplex SX280 Lower Fan Replacement: passo 7, immagine 1 di 2 Dell Optiplex SX280 Lower Fan Replacement: passo 7, immagine 2 di 2
    • Press on the blue release tab and remove the fan.
Conclusione
Altre 3 persone hanno completato questa guida.
Tom
Membro da: 10/04/10
841 Reputazione
7 Guide realizzate
Cal Poly, Team 22-4, Maness Fall 2010 Membro di Cal Poly, Team 22-4, Maness Fall 2010
CPSU-MANESS-F10S22G4
4 Membri
26 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 4,184
