Salta al contenuto principale
Dell Optiplex SX280 Battery Replacement
Cosa ti serve
  1. Dell Optiplex SX280 Battery Replacement, Panel Cover: passo 1, immagine 1 di 1
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Dell Optiplex SX280 Battery Replacement: passo 2, immagine 1 di 2 Dell Optiplex SX280 Battery Replacement: passo 2, immagine 2 di 2
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
  3. Dell Optiplex SX280 Battery Replacement: passo 3, immagine 1 di 2 Dell Optiplex SX280 Battery Replacement: passo 3, immagine 2 di 2
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
  4. Dell Optiplex SX280 Battery Replacement, Hard Drive: passo 4, immagine 1 di 2 Dell Optiplex SX280 Battery Replacement, Hard Drive: passo 4, immagine 2 di 2
    • Unplug the blue cable that connects the hard drive to the motherboard.
  5. Dell Optiplex SX280 Battery Replacement: passo 5, immagine 1 di 2 Dell Optiplex SX280 Battery Replacement: passo 5, immagine 2 di 2
    • Unplug the power supply, distinguished by its red and yellow wires (yellow wire obscured from view).
  6. Dell Optiplex SX280 Battery Replacement: passo 6, immagine 1 di 1
    • Squeeze the release tabs on either side of the hard drive.
  7. Dell Optiplex SX280 Battery Replacement: passo 7, immagine 1 di 2 Dell Optiplex SX280 Battery Replacement: passo 7, immagine 2 di 2
    • Slide the Hard Drive out while squeezing the tabs.
  8. Dell Optiplex SX280 Battery Replacement, Battery: passo 8, immagine 1 di 1
    • Under the hard drive, there is a circular, silver battery connected to the motherboard.
    • Use a spudger to gently pry the battery from the motherboard.
  9. Dell Optiplex SX280 Battery Replacement: passo 9, immagine 1 di 1
    • Lift the battery out of the motherboard.
  10. Dell Optiplex SX280 Battery Replacement: passo 10, immagine 1 di 3 Dell Optiplex SX280 Battery Replacement: passo 10, immagine 2 di 3 Dell Optiplex SX280 Battery Replacement: passo 10, immagine 3 di 3
    • Upon replacement, simply push the battery into the motherboard.
Conclusione
Altre 10 persone hanno completato questa guida.
Tom
Membro da: 10/04/10
841 Reputazione
7 Guide realizzate
Cal Poly, Team 22-4, Maness Fall 2010 Membro di Cal Poly, Team 22-4, Maness Fall 2010
CPSU-MANESS-F10S22G4
4 Membri
26 Guide realizzate
Un commento
that particular battery holder looked hard to get out- no pop out lever, thought i’d break it gouging it out!
neverts “itchytastyurr” ennud - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 11,767
