Introduzione
You should never try to repair a power supply unit. These are appropriately labeled, "Field Replaceable Units" for a reason. Disassembling a computer power supply unit can seriously harm and even kill you.
Parti
Nessuna parte richiesta.
Power down your PC and remove the power cord from the back. Power down your PC and remove the power cord from the back.
  • Power down your PC and remove the power cord from the back.
Aggiungi Commento
Press and hold the power button for about 10 seconds, then release. This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
  • Press and hold the power button for about 10 seconds, then release.
    • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
Aggiungi Commento
With the computer standing upright, firmly pull on the tab at the back of the computer.
  • With the computer standing upright, firmly pull on the tab at the back of the computer.
  • When the side panel pops free, gently pull the panel away from the computer.
  • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
Aggiungi Commento
Gently disconnect the power cables from the motherboard and drives. Gently disconnect the power cables from the motherboard and drives. Gently disconnect the power cables from the motherboard and drives.
  • Gently disconnect the power cables from the motherboard and drives.
Aggiungi Commento
Remove the four screws that attach the power supply on the back of the chassis.
  • Remove the four screws that attach the power supply on the back of the chassis.
  • Do not remove any screws that are not highlighted in red.
Aggiungi Commento
Press the blue release button. This is located on the floor of the computer chassis right in front of the power supply.
  • Press the blue release button. This is located on the floor of the computer chassis right in front of the power supply.
Aggiungi Commento
Remove the unconnected power supply by sliding it towards the front of the computer. Next, lift it up out of the chassis.
  • Remove the unconnected power supply by sliding it towards the front of the computer. Next, lift it up out of the chassis.
Aggiungi Commento
Conclusione
Altre 8 persone hanno completato questa guida.
Kristina
Membro da: 03/09/2014
144 Reputazione
8 Guide realizzate
Pasco Hernando, Team 5-1, Prince Fall 2014 Membro di Pasco Hernando, Team 5-1, Prince Fall 2014
PHSC-PRINCE-F14S5G1
10 Membri
8 Guide realizzate
Thanks, I followed the instructions, the replacement of the power supply unit was more simple than I expected
George
geotech78 - Replica
i replaced that but not repair this
Muhammad Qasim - Replica
At post Madasanal TQ disk bijapur
sidaray - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 50
Tutti i Tempi: 3,960
