Salta al contenuto principale
Dell Optiplex 745 Small Form Factor RAM Replacement
  1. Dell Optiplex 745 Small Form Factor RAM Replacement, Opening the case: passo 1, immagine 1 di 2 Dell Optiplex 745 Small Form Factor RAM Replacement, Opening the case: passo 1, immagine 2 di 2
    • Pull the tab and the lid will pop up.
  2. Dell Optiplex 745 Small Form Factor RAM Replacement: passo 2, immagine 1 di 2 Dell Optiplex 745 Small Form Factor RAM Replacement: passo 2, immagine 2 di 2
    • Grab the lid and pull it up and off.
  3. Dell Optiplex 745 Small Form Factor RAM Replacement, Disconnecting the cables: passo 3, immagine 1 di 2 Dell Optiplex 745 Small Form Factor RAM Replacement, Disconnecting the cables: passo 3, immagine 2 di 2
    • Pull out both sets of cables from the side of the optical drive.
    • Both cables are plugged into the drive right next to each other.
  4. Dell Optiplex 745 Small Form Factor RAM Replacement, Removing the optical drive: passo 4, immagine 1 di 2 Dell Optiplex 745 Small Form Factor RAM Replacement, Removing the optical drive: passo 4, immagine 2 di 2
    • Pull the tab up holding the optical drive in place.
    • Slide the optical drive out.
  5. Dell Optiplex 745 Small Form Factor RAM Replacement, Unlocking the RAM stick from the motherboard: passo 5, immagine 1 di 2 Dell Optiplex 745 Small Form Factor RAM Replacement, Unlocking the RAM stick from the motherboard: passo 5, immagine 2 di 2
    • Press down on the white tabs on both sides of the RAM stick until the RAM stick pops up.
  6. Dell Optiplex 745 Small Form Factor RAM Replacement, Lifting the RAM stick out of the case: passo 6, immagine 1 di 1
    • Gently lift the RAM stick up and out of the case.
    • When inserting a RAM stick, press firmly down into the slot until the white tabs lock into both sides of the stick.
Conclusione
Altre 7 persone hanno completato questa guida.
Cal Poly, Team 13-10, Forte Fall 2014 Membro di Cal Poly, Team 13-10, Forte Fall 2014
CPSU-FORTE-F14S13G10
6 Membri
12 Guide realizzate
Un commento
Dell master. I'm going to be the best repair pro on this side of the south side.
fixitbrosmsus - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,679
