Strumenti
Nessun attrezzo richiesto.
Parti
Nessuna parte richiesta.
Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you. Push the  oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
  • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
  • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
  • Note: Some force may be required to push in the oval buttons open the PC case.
cool de faires des sites comme ca :)
baptiste Prando - Replica
Identify the optical drive in the case. Remove the analog audio cable from the optical drive. Remove the IDE cable form the optical drive by pulling straight up on the orange plastic tab..
  • Identify the optical drive in the case.
  • Remove the analog audio cable from the optical drive.
  • Remove the IDE cable form the optical drive by pulling straight up on the orange plastic tab..
  • Remove the power cable from the optical drive.
Aggiungi Commento
Push the two green tabs toward each other to release the optical drive and lift it out.
  • Push the two green tabs toward each other to release the optical drive and lift it out.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Kevin Schapansky
Membro da: 05/10/2010
1.142 Reputazione
18 Guide realizzate
Cal Poly, Team 4-48, Amido Fall 2010 Membro di Cal Poly, Team 4-48, Amido Fall 2010
CPSU-AMIDO-F10S4G48
4 Membri
18 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 54
Tutti i Tempi: 7,841
