Parti
Nessuna parte richiesta.
Before removing the battery from the laptop, make sure the power is off.
  • Before removing the battery from the laptop, make sure the power is off.
  • Push both battery locking clips outward at the same time.
Aggiungi Commento
Slide the battery out of the laptop.
  • Slide the battery out of the laptop.
Aggiungi Commento
Remove the four 4-mm screws on the bottom of the laptop using a #0 screw driver.
  • Remove the four 4-mm screws on the bottom of the laptop using a #0 screw driver.
Aggiungi Commento
Carefully turn the laptop over and open the screen all the way. Locate the slot to remove the keyboard in the lower left hand corner.
  • Carefully turn the laptop over and open the screen all the way.
  • Locate the slot to remove the keyboard in the lower left hand corner.
  • Using a spudger as a lever, insert it into the slot and gently pry up.
Aggiungi Commento
After the keyboard pops up, pull it away from the screen just enough to release the tabs.
  • After the keyboard pops up, pull it away from the screen just enough to release the tabs.
  • Don’t pull the keyboard out forcefully as there is still a ribbon attached to the laptop.
Aggiungi Commento
Unlock the ZIF connector on the computer by pushing the two outside tabs toward the screen.
  • Unlock the ZIF connector on the computer by pushing the two outside tabs toward the screen.
Aggiungi Commento
Remove the flexible ribbon from ZIF connector.
  • Remove the flexible ribbon from ZIF connector.
  • Do not pull on the ribbon to remove it from the ZIF connector.
Aggiungi Commento
Position the laptop so that the bottom is facing upward.
  • Position the laptop so that the bottom is facing upward.
  • Remove the 3 #0 4 mm screws holding the bottom of the palm rest.
Aggiungi Commento
Return the laptop to proper position and open the screen.
  • Return the laptop to proper position and open the screen.
  • Remove the 6 #0 4 mm screws holding in the palm rest.
Aggiungi Commento
Gently lift the palm rest and rotate it outward so that the bottom is now facing up.
  • Gently lift the palm rest and rotate it outward so that the bottom is now facing up.
  • The ribbon attached to the track is short and extremely delicate. Use care when moving the palm rest.
Aggiungi Commento
Lift up on the small ZIF connector and remove ribbon.
  • Lift up on the small ZIF connector and remove ribbon.
  • If ribbon seems stuck gently wiggle it to remove. Do not pull ribbon with great force.
Aggiungi Commento
Conclusione
Thomas Wong
Membro da: 20/01/2012
23 Reputazione
2 Guide realizzate
Cal Poly, Team 11-20, Maness Winter 2012 Membro di Cal Poly, Team 11-20, Maness Winter 2012
CPSU-MANESS-W12S11G20
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 759
