Introduzione
Replacing a Latch on the Dell Latiude X300
Parti
Nessuna parte richiesta.
Make sure the power is off.
  • Make sure the power is off.
  • Remove the battery located on the bottom of the device by pushing in both clips.
Aggiungi Commento
Remove rubber caps on each corner of the front screen with a pinch. Remove the 4 mm screws located on the front screen of the laptop.
  • Remove rubber caps on each corner of the front screen with a pinch.
  • Remove the 4 mm screws located on the front screen of the laptop.
Aggiungi Commento
Carefully, remove the screen casing using either your hands or a proper tool.
  • Carefully, remove the screen casing using either your hands or a proper tool.
  • The casing is very flimsy, so use extreme care.
Aggiungi Commento
Remove the screws holding the latch in place.
  • Remove the screws holding the latch in place.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 159
