Parti
Nessuna parte richiesta.
Before removing the battery from the laptop, make sure the power is off.
  • Before removing the battery from the laptop, make sure the power is off.
  • Push both battery locking clips outward at the same time.
Aggiungi Commento
Slide the battery out of the laptop.
  • Slide the battery out of the laptop.
Aggiungi Commento
Remove the four 4-mm screws on the bottom of the laptop using a #0 screw driver.
  • Remove the four 4-mm screws on the bottom of the laptop using a #0 screw driver.
Aggiungi Commento
Carefully turn the laptop over and open the screen all the way. Locate the slot to remove the keyboard in the lower left hand corner.
  • Carefully turn the laptop over and open the screen all the way.
  • Locate the slot to remove the keyboard in the lower left hand corner.
  • Using a spudger as a lever, insert it into the slot and gently pry up.
Aggiungi Commento
After the keyboard pops up, pull it away from the screen just enough to release the tabs.
  • After the keyboard pops up, pull it away from the screen just enough to release the tabs.
  • Don’t pull the keyboard out forcefully as there is still a ribbon attached to the laptop.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Unlock the ZIF connector on the computer by pushing the two outside tabs toward the screen.
  • Unlock the ZIF connector on the computer by pushing the two outside tabs toward the screen.
Aggiungi Commento
Remove the flexible ribbon from ZIF connector.
  • Remove the flexible ribbon from ZIF connector.
  • Do not pull on the ribbon to remove it from the ZIF connector.
Aggiungi Commento
Position the laptop so that the bottom is facing upward.
  • Position the laptop so that the bottom is facing upward.
  • Remove the 3 #0 4 mm screws holding the bottom of the palm rest.
Aggiungi Commento
Return the laptop to proper position and open the screen.
  • Return the laptop to proper position and open the screen.
  • Remove the 6 #0 4 mm screws holding in the palm rest.
Aggiungi Commento
Gently lift the palm rest and rotate it outward so that the bottom is now facing up.
  • Gently lift the palm rest and rotate it outward so that the bottom is now facing up.
  • The ribbon attached to the track is short and extremely delicate. Use care when moving the palm rest.
Aggiungi Commento
Lift up on the small ZIF connector and remove ribbon.
  • Lift up on the small ZIF connector and remove ribbon.
  • If ribbon seems stuck gently wiggle it to remove. Do not pull ribbon with great force.
Aggiungi Commento
Remove the #00 4 mm screws holding the speakers in place.
  • Remove the #00 4 mm screws holding the speakers in place.
Aggiungi Commento
Gently pull the speaker cable out.
  • Gently pull the speaker cable out.
  • If the wire is tight, wiggle it back and forth but don’t apply too much force.
  • Do not use the speaker wire to pull itself out of the connector.
Aggiungi Commento
Pull the speakers straight up and out of the laptop.
  • Pull the speakers straight up and out of the laptop.
Aggiungi Commento
Conclusione
Elai Fresco
Membro da: 20/01/2012
7 Reputazione
2 Guide realizzate
Cal Poly, Team 11-20, Maness Winter 2012 Membro di Cal Poly, Team 11-20, Maness Winter 2012
CPSU-MANESS-W12S11G20
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 868
