Introduzione
Replacing the intel wireless card, available for around 5 dollars on ebay
Strumenti
Nessun attrezzo richiesto.
Find the battery
  • Find the battery
Aggiungi Commento
Pull the tab to release the battery Pull the tab to release the battery
  • Pull the tab to release the battery
Aggiungi Commento
Pull the battery out
  • Pull the battery out
Aggiungi Commento
Use your screwdriver to unscrew and lift up the panel on the right labeled with a C
  • Use your screwdriver to unscrew and lift up the panel on the right labeled with a C
Aggiungi Commento
Pull off the two wires connected to the wireless card
  • Pull off the two wires connected to the wireless card
  • They should come off fairly easy
Aggiungi Commento
Pull the two tabs away from the card and pull up on the intel card Then pull it away from the holding slot to remove it
  • Pull the two tabs away from the card and pull up on the intel card
  • Then pull it away from the holding slot to remove it
Aggiungi Commento
When placing in your new wireless card, connect the two wires before inserting into the slot Then line it up, put the card in at an angle and push down so the side tabs lock it into place
  • When placing in your new wireless card, connect the two wires before inserting into the slot
  • Then line it up, put the card in at an angle and push down so the side tabs lock it into place
Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
Joseph
Membro da: 16/07/2014
1.427 Reputazione
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,890
